Use WOT nitrous switch for drop resister mod?
Old Mar 29, 2005 | 05:02 PM
theMax's Avatar
Can you use the same switch?
I know the nitrous is normally open and the drop resister is normally closed, but any suggestions?
Old Mar 29, 2005 | 05:14 PM
brad kay
nitrous is normally closed and drop resistor is normally open. i realize that didnt help the discussion at all.
Old Mar 29, 2005 | 05:40 PM
Jime's Avatar
Definately will not work, unless of course you reverse it to N/C using a relay.
Old Mar 29, 2005 | 06:47 PM
theMax's Avatar
So I can use the swich for the nitrous and use a relay for the tranny?
If I use a a hot lead and use the switch to complete the ground through the relay? or just use 2 switches....
Old Mar 30, 2005 | 03:54 AM
Jime's Avatar
You use the switch which is N/O (wrong polarity) to switch a relay which has both N/O and N/C outputs. Connect the N/C output connection of the relay to the drop resistor circuit.
Just using a N/C switch instead is much easier, all I was commenting on earlier was that you could use the switch, however its much more complicated.
Just get one of these micro switches instead, it has both N/C and N/O connections.
Old Mar 30, 2005 | 10:32 AM
theMax's Avatar
Great, so with the above switch the tranny will be connected and nitrous not and at WOT, it disconnects the tranny and connects the nitrous, perfect.
With this setup you will be sharing the common, do you see a problem with this?
Off to radio shack...
Old Mar 30, 2005 | 12:17 PM
Jime's Avatar
Don't think I would share the common to be safe, just use 2 switches, they can be bolted and attached together. It would probably be ok if you didn't connect the 12v to the common but for a couple of bucks use separate switches.
Old Mar 31, 2005 | 06:11 AM
theMax's Avatar
Sounds like 2 switches it is. Thanks, now to finish up the install and get to the track!
shilov
Feb 19, 2024 09:40 PM
Excalibur23
Oct 13, 2015 04:33 PM
James92SE
Oct 8, 2015 04:57 PM
carid
Sep 17, 2015 05:00 AM
dcardello
Sep 3, 2015 11:44 PM
