Newb Looking For Nitrous...
Old May 18, 2005 | 10:41 PM
slammed's Avatar
I have a 1996 Maxima Automatic (126K miles)
I need your guys help
Recommend me a kit thats best for me
My Mods:
Y-Pipe
Air Intake
Full Cat Back Exhaust
UDP
I basically want to leave everything stock in my engine (except for my plugs)
I read up on Nitrous, and I am leaning towards NX. I was looking to get the 75 shot, but I do not want to upgrade my fuel pump.
Dry or Wet?
NX or ZEX?
thanks
Old May 18, 2005 | 11:06 PM
slammed's Avatar
OK...I decided to go with the Wet NX Stage 1 kit....
Nitrous Express states that with this kit nothing needs to be modified...does this still apply if I decided to get a 75 shot setup?
Old May 18, 2005 | 11:29 PM
99Maxxx's Avatar
ok, so I made the mistake of buying a buddy's used NOS kit. It's a universal dry kit, but was installed on his mustang. I know I will have to get different jets and a different fuel pressure reg. tee, but the kit only came with one solenoid. Am I missing something here?
Old May 19, 2005 | 03:38 AM
Jime's Avatar
Apart from the plugs you should be good to go. The fuel pump if in good condition should handle the 75 maybe even a 100 shot, but a fuel gauge will let you know pretty quickly. I use a mechanical gauge (approx $10) with a rubber hose under the wiper blades to watch it while testing. Just connect it into the Tee you will need to get fuel for the fuel solenoid.
I recommend the Iridum plugs, currently I am using 2 step colder and have just run my fastest N/A time of 13.4.
For plug size check the chart on my homesite.
PS Before you do the 75 though play with the 35 for a bit to make sure everything is working before you move up.
Old May 19, 2005 | 07:16 AM
SonicDust187's Avatar
If you want want egt and fp gauge, I have them for sale.
Old May 19, 2005 | 09:11 AM
CalsonicSE's Avatar
My 05124 dry NOS kit came with 2 solenoids. The only nitrous kit that I've seen that utilizes only 1 solenoid is the JWT/NOS dry kit, but you need the nitrous ECU for that.
Old May 21, 2005 | 06:36 AM
Zyzzyan's Avatar
newb and NOS do not go together.
Old May 21, 2005 | 03:34 PM
ttmax's Avatar
I here people talking about retarding there timing how do u do that on a maxima i havent seen a where to ajust it
Old May 21, 2005 | 05:13 PM
fmaru's Avatar
i agree Z!
Old May 21, 2005 | 07:20 PM
subs1000w's Avatar
its not required untill high amounts of nitrous is injected like 100+ (or untill detonation becomes a problem)
if you have a pre 95 max you can adjust it but if you have a 95+ max its all done in the computer
Old May 21, 2005 | 08:01 PM
Brushedpewter's Avatar
If you have a distributor then it's a lot easier to retard the timing. It costs about $400 for the whole MSD package but it retards the timing when the nitrous is spraying and there is a stronger spark. There are a lot of other features.
BeutiusMaximus
Apr 18, 2004 01:28 PM
Liquid_pjear
Apr 8, 2004 05:19 AM
bi0_gauss
Oct 20, 2003 10:00 PM
MAXIN
Feb 8, 2003 10:02 AM
