Will this Fit?
Old Aug 9, 2005 | 04:52 PM
Trevmister1610's Avatar
Will this Fit?
http://cgi.ebay.com/ebaymotors/EFI-N...67145653QQrdZ1
thanks
Old Aug 10, 2005 | 03:47 AM
Jime's Avatar
It will fit. Do you want to see whats in the pretty purple box?
I really don't have anything against Zex even though I think NX is the best setup. However if you are bent on getting Zex get the wet kit not the dry.
Old Aug 10, 2005 | 07:52 PM
do u have a link with a nx kit that will fit? i havent been able to find 1
Old Aug 10, 2005 | 08:40 PM
Jime's Avatar
http://forums.maxima.org/showthread.php?t=368479
Old Aug 10, 2005 | 08:44 PM
k thnks but i am lookin for a dry kit
Old Aug 11, 2005 | 03:40 AM
Jime's Avatar
I you want to run your fuel system at 80-100 psi and force the extra fuel needed through the injectors ok. But remember it only takes one of your injectors to get plugged or fail and your engine is toast. Not that it will happen but the chances are much higher with a dry system.
My first system was a dry NOS setup before I went to the wet NX and I would never go back. Easier to tune, safer, doesn't requre an upgraded fuel pump and FPR until you hit approx 100 shot etc. Also NX has a lifetime warranty on the solenoids.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Pied
Sep 26, 2015 03:29 PM
