blowing fuses
Old Oct 8, 2005 | 11:01 PM
ttumaxima's Avatar
blowing fuses
alright, for some reason, every time that i spray, i blow the inline fuse between the battery and the solenoids.....i thought it was the wiring at first, but then i rewired the whole system, and it still does it.....
i'm at a loss, don't really know what it could be. its gettin kinda annoying to have to change the fuse everytime that i spray my car.
any ideas would be great....
Old Oct 9, 2005 | 12:56 AM
jcy98maxse's Avatar
Turbo is too much fun!
sounds like a short somewhere. U make sure that no grounds are connect to and + leads? Are you running a relay? What instructions are you going off of?
Old Oct 9, 2005 | 12:22 PM
JUICED's Avatar
are you using the right fuse?
Old Oct 11, 2005 | 09:42 AM
ttumaxima's Avatar
it's wired up per nitrous express's instructions, using the provided harness, and there are grounds.....i'm using a 20 amo fuse, is that the right one? it came with a 20 amp fuse when i bought the kit.......
Old Oct 13, 2005 | 06:43 AM
C MAX's Avatar
recheck your ground this is almost always a sign of ground problems, or power line touching somewhere or wires crossed.
Old Oct 13, 2005 | 09:43 PM
wunfstmax's Avatar
Its probably shorted to a ground. You can use a multimeter and see if you have any power on your ground, if you do then thats your problem.
Old Oct 18, 2005 | 09:06 AM
ttumaxima's Avatar
i think that i ust got a couple bad fuses or something, cause the one thats in there didn't blow all weekend....i dunno, i'm gonna test the ground wire anayway, though.....
thanks for the help
tarun900
19
Dec 20, 2021 06:57 PM
leatherneck
Sep 30, 2015 09:16 PM
Noela
Sep 26, 2015 08:22 AM
