Want to do over 100 shot
Old Jan 4, 2006 | 12:26 AM
sciff5's Avatar
Hey guys I have been thinkin alot about what the best way to get the most HP/dollar out of my max while keeping it reliable. After playin with the idea of a turbo or super charger the numbers just didnt add up. After some more reasearch I have found that adding sleeves to the engine and increasing displacement with some forged internals should allow me to rev to around 9k rpm and get around 350hp at the crank as a conservative figure. From there I want to run a 100-150 shot of nitrous and wanted to know what the weakest parts of the engine are that would need reinforcing. I am guessing I would want to do direct port injection with a shot this big and I would also want to address the fuel concern when running a wet shot this large.
How much would running a shot like this cost?
With tuning this car should put out 500 crank hp VERY easily, and I still think it would be cheaper than doing the 4.3L stroker kit or a tubo kit.
Old Jan 4, 2006 | 12:10 PM
CBass69187's Avatar
Yes you can add displacement with different internals, but why would you want to rev to 9k? I think with an increase in displacement (>3.8L), full supporting mods and proper tuning you would be in the 275 whp range (obviously hp figures are dependent on engine displacement and quality of parts selected). If you did some head work (cams, larger valves, port job) you could push that to around 300 whp. You should be able to run your 150 shot without worrying about structural defencies because you stated that you would be running aftermarked forged internals. As long as you are supplying the necessary fuel and you have good tuning you should be alright from that aspect. If you have a 6 speed, get it cryo treated, etc and if you are an auto i would have it built. Considering the cost involved in this, it wouldn't hurt to consider an aftermarked LSD and a good set of slicks for the track.
As far as cost is concerned, most of your money will be spent on your engine work. Not too much is needed to run a 100 shot on a vq35 (can be done on stock engine).
Old Jan 24, 2006 | 06:23 PM
KRRZ350's Avatar
Why don't you just drop a 3.5 in that thing, you can get them for between $800-$1000 with very low miles, and you can sell off your 3.0 to cover a tiny bit of that, hell for that price you could buy two of them and throw a 225 shot on one of them just to see what brakes!
Old Jan 24, 2006 | 06:46 PM
brad kay
as far as your nitrous system and the necessary upgrades you will need to safely run the shot you want, you should search this forum, there are bagillions of responses as to what fuel system and ignition system upgrades you will most likely want, and what systems you can use to easily tune and monitor your setup
also, whether you want to run direct port or not is a choice you'll have to make up front. A wet shot single nozzle system will support shots to 150 hp + safely, honestly I havent heard of any maxima detonating in cylinder 3 or 6 because it ran lean due to insufficient fuel uptake from a single nozzle wet kit or anything, so that decision is up to you.
Whatever you chose, good luck with your project!
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
Andy29
Sep 29, 2015 05:32 AM
