How do you set the fpss? (hobs switch)
Old Jan 18, 2006 | 08:13 PM
Donkeypunch's Avatar
It came with the kit but I never put it on. I've
read acouple walk throughs online but don't really understand.
For those of you that don't know what I'm talking about.
It shuts off the ground to the solenoid when the fuel pressure drops under
whatever psi you set it at. Just like a pressure based bottle heater.
lol, no love for n.o.s? ------->
Old Jan 19, 2006 | 04:49 AM
Jime's Avatar
You take the little rubber cap off the top and adjust the screw to change the pressure. You need a pressure gauge and a multi-meter to measure the resistance across the 2 contacts so you know when its an open or closed circuit. Just make sure to adjust it at least 5 psi lower than your fuel pressure because when the fuel solenoid opens you get a momentary drop in pressure.
Old Jan 19, 2006 | 01:26 PM
NisMo-Max's Avatar
where u can find the Fpss.
Old Jan 19, 2006 | 09:18 PM
Do I spray and set it that way or what?
Seems like a big waste of nitrous.
How did you guys set it up?
Old Jan 20, 2006 | 02:09 AM
Jime's Avatar
No you don't spray while setting it up. You will have to disconnect the nitrous solenoid to test and adjust it.
jsmith24
Feb 1, 2016 12:35 AM
James92SE
Oct 8, 2015 04:57 PM
hozay99
Sep 19, 2015 10:20 PM
240tomax
Sep 13, 2015 03:28 PM
