What plug to spray 5th Gen
Old Feb 20, 2006 | 11:39 PM
dafertilizer's Avatar
I have read that for spraying, to switch to a slightly cooler plug, and to use a copper plug with a smaller gap (allowing a more dense spark to ignite the gas)
So my question is, which copper plug do any of you use? I found these two NGKs, byt they are stock for the Max, and I read that yor are supposed to use a colder plug:
v-power
http://www.ngk.com/more_info.asp?AAIA=1359222&pid=3484
regular
http://www.ngk.com/more_info.asp?AAIA=1359222&pid=2581
And what should they be gapped to???
Oh I am putting in a VEX 75 shot dry, w/no exhaust mods, just an intake.
Old Feb 21, 2006 | 04:44 PM
xlcrew's Avatar
I’m Back
check out JIME's webpage. he has a list of everything.very helpful
Old Feb 21, 2006 | 09:15 PM
Yes it was, I got all the plug numbers I needed, but I do have one more question about the plugs;
If I put in a colder plug, what ways will this affect my daily driving? harder cold starts?
Old Feb 22, 2006 | 02:11 AM
Donkeypunch's Avatar
Too cold, and you'll foul the plugs = rough idle and hard starts.
On most imports 2 steps colder is fine with daily driving.
Just let the car heat up so they can "self clean" and don't drive like
a grandma 1mile a day. :P
Old Feb 22, 2006 | 04:55 AM
Yeah I think I'm only gonna go the 1 step colder, and I drive about 80-100 miles a day to school, so I'll try to keep it as non-grandma as possible
Old Feb 22, 2006 | 07:02 AM
SDot82's Avatar
Would the gap be the same for 1 step colder plugs as they are for 2 step colder plugs?
Old Feb 22, 2006 | 01:13 PM
yeah.
Basicly the "colder" it is, the more heat it takes out of the cyl. It's not
that the actual spark is weaker or burns "colder".
I think it was up to 70 degress for every heat range according the NGK.
Old Feb 22, 2006 | 07:18 PM
t6378tp's Avatar
Turbo 3.5
sorry for goin off the subject alittle but I am looking to add a 50 shot dry system or a jwt/ts ecu which would be better this is a daily driver for me
mods: injen cai, budget y pipe, flow master muffler, lower 1.6, 18inch wheels, stillen front lip, drop res mod, full audio/video, clear bumpers
thanks for any help and suggestions
Old Feb 22, 2006 | 07:43 PM
00SEMAX19's Avatar
Nitrous will give you more Hp when spraying of course. Ecu will help always, but I think you don't want to do both because timing advance will cause problems with the nitrous. If you don't plan on going to the track much then go for the ecu. but if you want bragging right times in the 1/4 then get the spray. Other than that look around the forum's you can find damn near any info you want without horing up other peoples threads with questions like this.
Old Feb 22, 2006 | 11:55 PM
Got the BKR6E-11 NGK's there one step colder then the OEM, and going to re-gap them to .035
Old Mar 2, 2006 | 08:51 PM
Andrey3000's Avatar
GOOD BOY
Old Mar 8, 2006 | 12:29 PM
NisMo-Max's Avatar
Can u just take 1 step colder plugs and put them in and run nitrous? Or do you have to regap them? I just put mine in, but what is the purpose of them regaping? I have the Denso Iridum 1 step colder, and your not allowed to regap those because they say it can break because of the fine point..
Old Mar 9, 2006 | 12:27 PM
With more fuel and air being cramed in the cyl.
spark is going to have alittle trouble jumping the gap and missfire.
Trying it out, if it missfires, gap it down alittle and do another run.
You won't have to gap a colder plug down any diffrent then you
would you'r stock plugs
You won't lose or gain any more power w/colder plugs.
A colder plug doesn't mean the spark is colder or weaker. :/
If you idle like crap or can't even turn the car on, you went
too cold and fouled the plugs.
I made 52hp and 76tq to the wheels with a dry
and had to gap my plugs to 25 from 28.
Old Mar 9, 2006 | 08:31 PM
check out Jime's website: http://jime.homeip.net/
he has it all on there, I went with the copper plugs, the Iridium plugs apparently have too small of a surface area for good spark with nitrous, the copper plugs have a much bigger surface area for the spark.
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
Lowered_a33
Sep 1, 2015 07:49 PM
