Retarding Timing with Nitrous
Old Mar 4, 2006 | 09:48 PM
k2max_driver's Avatar
just wanted to know if anyone in the community has ever retarded there timing a degree or two when installing a nitrous kit. my friend told me that you should atleast retard timing one or two degree for every 50 horses. which makes sense to me because you certainly do not want to pre-detonate. just wanted to hear your guys's take on the whole subject especially everyone that is running a 50shot 75shot and 100shot.
thank you for your time and please don't hesitate to reply
Old Mar 4, 2006 | 10:54 PM
streetzlegend's Avatar
well yea its suggested to retard timing, but the thing is... how do we retard timing on our cars?
Old Mar 4, 2006 | 11:15 PM
vq356sp's Avatar
El Mas Noob Del Org.
My car is retarded jk from what i hear this is good on hondas havent heard too much on the subject with maximas but good question i too am interested.
Old Mar 4, 2006 | 11:40 PM
Deckdout2's Avatar
Play with my balls
you'll be fine. I'm spraying mine advanced.
Note: not responsible for your car.
Old Mar 4, 2006 | 11:49 PM
NisMo-Max's Avatar
Im also Spraying with Advance.
Note: Not responsible for your car
In order to retard timing you need to go to the dealership, and have them use the Consult 2 to retard/Advance...
Old Mar 5, 2006 | 05:32 PM
CalsonicSE's Avatar
J&S Safeguard
Old Mar 6, 2006 | 07:28 AM
Andrey3000's Avatar
I retarded my timing at the diler, it was only $86 ( hour of labor). I talk to the guy and he told me that for evrey 50 shots you need 1 degree, to run cooler detonation. but if you retare timing you loose just a bit of top end tork, it's OK you safe and you got a bottle
Old Mar 6, 2006 | 05:16 PM
you guys with your timing advanced are just asking for predetonation
Old Mar 11, 2006 | 09:11 PM
qnpark8282's Avatar
get colder plugs to retard timing.
Old Mar 12, 2006 | 02:03 AM
glenmoormax's Avatar
10 psi
i run stock ecu with two step colder plugs and they are gapped at .035, i haven't had problems with pre detenation spraying 100 thus far, (except when i bogged accidentally and sprayed) but I think the best way to go about it is your spark plugs first, FP and FPR, then retard your timing... just a rookie's advice though...
Old Mar 12, 2006 | 03:31 AM
C MAX's Avatar
K2max your boy is abosolutley correct. normally anything up to a 60 shot it isnt needed, but anything higher it is a great plus. when i ran 60 shots i didnt change anything and like i state in many post's i beat the hell out of that 60 shot,lol. now i wouldnt suggest going to your dealer to have it permanently retarded because then your car would run slow N/A as well. after going threw a couple of motors from detonation i now retard my timing for high shots. some guys use msd or some other device but i use J&S. i retard 2 degrees when i spray a 75 shot, because this helps in delaying detonation or preventing it totally. and advancing is out of the question.
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
kjlouis
Oct 3, 2015 05:29 AM
trungg86
Sep 4, 2015 04:58 AM
Wareagle92
Sep 3, 2015 07:18 PM
