Do I have everything I need?
Old Mar 22, 2006 | 08:15 AM
Bluemax95's Avatar
I am about to go pick up my kit today. I am very excited about seeing just how much different the car will feel on the bottle. This is everything I ordered let me know if you guys see anything else I may need to purchase so that I don't blow myself up.
1 - Zex #82021 "55-75 Wet Kit"
1- Autometer Nitrous Pressure guage
1- Autometer Air Fuel Guage
I am looking for a "slightly used" Fuel Pressure Guage to match (Autometer Ultra lite)
Old Mar 22, 2006 | 10:40 AM
C MAX's Avatar
to stay consistent you might wanna get a bottle heater and a blanket.
Old Mar 22, 2006 | 11:01 AM
SDot82's Avatar
FPSS might be a good idea.
Old Mar 22, 2006 | 05:13 PM
Donkeypunch's Avatar
That a/f guage is useless. Take it back if you can.
A window switch you should get too.
Instead of useing the fuel from the gas tank you could get a
1gal fuel cell and fill it with race gas so when you spray you can
use a much higher shot without detonation on pump gas.
That gallon would probably last you a month at 5.00 a gallon that's the
smartest idea even if you run 87 that'll save you money and still give you a much
higher octane rating then what you get at the pumps.
...and get some slicks :P
Old Mar 22, 2006 | 07:04 PM
glenmoormax's Avatar
10 psi
The a/f is useless, and annoying, get the MSD window switch..
the fuel cell in my opinion would only be useful if he were planning on running 100 shot or more, even then i spray 125 on 91, but race gas is a good way to prevent detenation, just not a necessity.
slicks, bottle heater
BTW nice times on your 1/4...
Old Mar 22, 2006 | 07:45 PM
Bluemax95's Avatar
Ok so I guess Ill return the A/F guage and get a bottle warmer. My firend has a A/F gauge and you guys are right it is very annoying. Sorry about my nitrous noobyness, but i am guessing a window switch initiates the nitrous only inside of a certain "window" of RPMS?
Old Mar 22, 2006 | 10:35 PM
10 psi
i would look into a purge kit as well and possibly a remote bottle opener, but its your call, just some more nitrous goodies..
860 Performance Billet Bottle heater kit at http://www.dynotunenitrous.com is a great bottle heater. Its what i have and i like it a lot.
Possibly if you want to spray more just get a walbro 190 FP and an adjustable FPR and run 100 to 125 shot...
Old Mar 23, 2006 | 07:19 AM
Bluemax95's Avatar
Yeah after the heater, a purge kit is definatly next. Do I not need larger injectors to spray a 100-125 shot? or is that only with a dry shot since with the wet extra fuel is being sprayed with the N02?
Old Mar 23, 2006 | 08:37 AM
Andrey3000's Avatar
What abut clutch? I don't know how many shots you going to use, but you need to change clutch. And I have a question to all other people with 5 speed. ANY PREFERENCE ON CLUTCH?
Old Mar 23, 2006 | 10:21 AM
Bluemax95's Avatar
I have already upgraded the clutch...I went with an XTD Stage 3 (good for 450 bhp) It takes a little getting used to the feel, but passengers can't tell from stock anymore.
Old Mar 23, 2006 | 08:19 PM
10 psi
good clutch upgrade? depends what you want to use, i would say exedy's are a great clutch, but 125 shot was a lot to handle for my exedy stage one... my other friend has a stock clutch and sprayed 125 a lot, 150 a couple of times even 175 once on it and its still fine...
you can spray up 125 with out injectors, yes...
Old Mar 26, 2006 | 03:10 PM
Deckdout2's Avatar
Play with my balls
Curt let me know if you need any help with your spray. I sold my zex that I had, but will be getting another kit in the future. If you need install help on the max just hit me up.
Old Mar 26, 2006 | 07:03 PM
Bluemax95's Avatar
Thanks man Ill give you a call if I run into any issues. I still got your #. My girls birthday is this weekend so I havent had much time for the install. I took about an hour today and mounted the bottle and management Unit. Tapped the TPS wire and grounded the box. Ran nitrous in and feul in. This week ill find time to finish up. Thanks.
Old Mar 28, 2006 | 01:25 PM
Deckdout2's Avatar
Play with my balls
No problemo. Sounds like you got a good portion done. Running the nitrous line isn't too bad. I do wanna ride.
I'll be in Charleston this coming weekend.
Old Mar 28, 2006 | 01:32 PM
Bluemax95's Avatar
Ill give you a call once I get everything installed, Ill have everything in wednesday, except the bottle. I was an idiot last night and stripped the threads off the bottle nut, so I had to order another one, should be here thurs or friday. Hopefully I can get everything working by this weekend so I can take her to the track next weekend.
Old Apr 27, 2006 | 09:39 PM
siren001's Avatar
What do you guys mean about fix tranny first? trans cooler? and valve body mod? WOT switch?>
