Correct spark plug gap question
Old Jun 13, 2006 | 12:21 PM
vq356sp's Avatar
El Mas Noob Del Org.
I was wondering if anyone can tell me what the correct gap is for the plugs on an 02 max w/75shot BTW 2 step colder plugs if that matters. Thanks I tried searching but could not find.
Old Jun 13, 2006 | 12:42 PM
grey99max's Avatar
LandShark has Cosworth
.035 is a good place to start, IMHO......
Old Jul 26, 2006 | 09:50 AM
vq356sp's Avatar
Can anyone confirm or tell me what your plugs are gapped at? Thanks
Old Jul 26, 2006 | 11:45 AM
Donkeypunch's Avatar
If you're not sure gap them to stock, do a run, and
see if they blow out; If they do, gap them down by .002 or something.
Or get a crane or msd box
Old Jul 26, 2006 | 02:08 PM
glenmoormax's Avatar
10 psi
.35 will work....
Old Jul 26, 2006 | 02:22 PM
vq356sp's Avatar
Thank you very much, .35 it is!
Old Jul 26, 2006 | 03:12 PM
NisMo-Max's Avatar
I have Denso Iridium 1 step colder plugs, but a few people told me you can not regap them. Would they sill be fine.. for a 75 shot?
Old Jul 27, 2006 | 09:17 AM
vq356sp's Avatar
Did they give you a reason as to why you cant regap them?
*Edit* I just received my new spark plugs today and I guess NisMo Max was correct. On the invoice it says " DO NOT GAP IRIDIUM PLUGS, YOU WILL SNAP THE CENTER ELECTRODE"
Old Jul 27, 2006 | 10:45 AM
grey99max's Avatar
I gapped two sets of iridium plugs when I was trying them w/nitrous. Set the plug in a vise, tap down on the steel ground strap and use a feeler gauge between taps - don't leave the gauge in while closing down the gap - this way you never touch the center electrode. Worked fine to close the gap to .035.... I melted the grounds and several center electrodes w/150-shot, and gave up on iridium plugs.
I went on to the cheapo copper/steel plugs (two steps colder) and had my best runs with those when I cut down the ground electrodes on each plug and gapped them to the side of the center electrode.
Old Jul 27, 2006 | 10:51 AM
NisMo-Max's Avatar
So i just put the Plugs in and i left them alone, But now im running 75 shot nitrous. Is that still OK....
Old Jul 27, 2006 | 11:19 AM
streetzlegend's Avatar
are you sure u were able to get 2 step colder for ur 3.5? cuz they used to not have them available. either way, yes you should gap them at .035
Old Jul 27, 2006 | 11:26 AM
vq356sp's Avatar
Yup here is the thread/chart that helped me find them a year ago.
http://forums.maxima.org/showthread.php?t=414115
mvm062
Nov 30, 2020 09:00 AM
9aj9
Apr 5, 2020 12:11 AM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
