nitrous kit
Old Aug 2, 2006 | 06:56 PM
sandeep's Avatar
nitrous kit
hey guys i am thinking about getting a nitrous kit for 99 sel 5 spd.. i dont know how many shots i should go with .. i am just thinking about 35 shots beacuse i dont wanna damage the motor .. can go more up safely or what >. so scared about damanging motor ... any one with opinion let me know thak u all>.
Old Aug 2, 2006 | 07:48 PM
vq356sp's Avatar
El Mas Noob Del Org.
Sounds like you have an idea, but do yourself a favor and read as much of this (including links)http://forums.maxima.org/showthread.php?t=167453 as possible then if you still have questions im sure we will all be glad to help..........
Old Aug 3, 2006 | 02:32 PM
streetzlegend's Avatar
I agree, just read through the link provided above and get a basic understanding of everything about nitrous and our car. but for a quick answer, any size shot can damage your engine no matter how small it is, even a 35shot can damage your engine if you dont know what your doing. Under properly working conditions a nitrous setup can be used to about 75shot without having to worry alot about damaging your ending. or maybe a 50 or 55shot to be more on safe side.
Old Aug 3, 2006 | 07:32 PM
sandeep's Avatar
ohh ok thanks guyz
Old Aug 5, 2006 | 05:45 AM
MajorMods's Avatar
when ur done reading it... there is a buddy of mine on sr20forum, he has the nx dry kit with purge and remote bottle opener... hes selling the kit for $325 + shipping. Its a good deal when ur ready to spray and ill ask him. He is actually in Buffalo Grove, IL
Old Aug 5, 2006 | 06:21 AM
mjk's Avatar
mjk
Head shot!!!
good deal, but how old is the kit?
Old Aug 5, 2006 | 10:19 AM
NAS's Avatar
NAS
just fyi but you can still get the NX wet kit from NOPI=$433 what I paid shipped to my door, like the others said read read read, thats what I did and so far no problems just ran out of $$
wish list from
Dynotunenitrous.com
bottle heater, afr gauage, N20 gauge
Old Aug 5, 2006 | 11:03 AM
mjk's Avatar
mjk
Head shot!!!
NX kit is the way to go. especially if you get the Genx kit with it.genx2 is a waste of money in my opininion.. unless you actually like to purge...
wish list from
Dynotunenitrous.com
Old Aug 9, 2006 | 01:09 PM
smotz's Avatar
Brain phuck
Unless you want to call Vin Diesel up and have him help you change your piston rings after every nitrous spray and risk having pistons come through your hood stay away. Ah, dont forget to double clutch also!
Just joking.. Dont believe anything you see or hear on TV about nitrous man
If your engine is in good shape now, nitrous won't hurt it. Just make sure all your sensors are good. Knock sensor and o2 sensors, and make sure your coils (things that go onto the spark plugs) are good.
Get the NX wet kit and start and stick with a 75 shot. Don't waste your time with the 35 or 50 shot, because guranteed after you hit 35 or 50 shot one time you will want more and put the 75 in.
Read as much as you can tonite and order the NX wet kit in the stickie tomorrow. Read the manual that comes with it and check their website then install it. Put the car in 2nd gear, slow down to 35 mph and hit the juice.
Never spray lower then 3k rpms (unless your in 1st, then you can spray whenever you want)
Your car wont break apart and everything isn't going to get blurry when you hit nitrous like it does in the movies. your car will simply accelerate a bit faster and it will sound as smooth and the same as it does when you floor it without nitrous, just it will rev and go a little faster.
NX says you can do a 20 shot for every cylinder without causing noticible wear to the engine. So a 75 shot is perfect. Get 2 step colder copper spark plugs ($1.15 each) If you need some pics or help setting it up just check the forums and stickies, and if you really get stuck send me a PM and I can provide some pics and advice. I'm not an expert or anything but I have ran into a few issues and have used quite a bit of nitrous over the past 8 months or so. Hope this is helpful.
Old Aug 9, 2006 | 07:06 PM
grey99max's Avatar
LandShark has Cosworth
Pretty good advice. Have you had your car on the track? Any good numbers to share? Just curious about how a 75-shot worked for you....
Old Aug 9, 2006 | 07:41 PM
sandeep's Avatar
thanks for info smotz>>.
Old Aug 10, 2006 | 06:16 AM
yea smotz put it pretty good listen to him. also when you get the nx kit, read the lil manual it comes with, it explains alot of things or u can even get it on their website. It even tells you to not listen to ur friends, magazines about nitrous lol. like on my sig below. So just follow directions, search this nitrous forum and then ask questions and you should be good. pz
Old Aug 10, 2006 | 09:26 AM
smotz's Avatar
Brain phuck
Look at my Sig
Old Aug 10, 2006 | 12:17 PM
grey99max's Avatar
Look at my Sig
OK - with that trap speed, you're making good HP. Have you tried DRs or slicks at the strip? 13's are really just around the corner!
Old Aug 10, 2006 | 01:01 PM
smotz's Avatar
Brain phuck
Ya for sure. The car is already in the 13's I just havent been able to get enough traction to prove it haha
Apr 16, 2020 05:15 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
Pied
Sep 26, 2015 03:29 PM
