Window Switch?
Old Aug 4, 2006 | 06:25 PM
Godson's Avatar
Window Switch?
Ok,sorry if this is asked alot and I look thru the stickies and only found mention of this,not an explanation on how it works. I wanna buy a dry kit for my 97 automatic but I wasn't sure about how it worked with the WOT during the shifts. I have a wet kit on my drag bike but I also use an air shifter so the shifts are very fast,so need to worry about spraying in between shifts,nut on an auto I'm confused about just how it should work. So I read thru the stickies and saw a post that said it was not a problem but here are my main questions: If I'm WOT AND have the button engaged,is this gonna be ok when the car shifts? Should I look into one of these "window switches" that is mentioned in the sticky?What does it do and how does it work? Also any other insight is greatly appreciated....thanks
Old Aug 5, 2006 | 09:14 AM
Godson's Avatar
Oh man, I hope this isnt thatdumb of a question
gavin68
Sep 18, 2021 12:36 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
