How good is the fuel fittings/lines in NX Import Kit
Alot of people seem to be complaining about small lines, small T fittings, stuff like that, what HP levels are the lines that come with the "All Import Stage 1" kit by NX good up to?
'Bout 35 hp..... Don't use it
- build one with 5/16" - 1/8"NTP adapters.Something like this:
Of course, this is for a dual-stage NX, but you get the idea. The parts are cheap and most hardware stores have it all....
Originally Posted by Maximahappy22
I need to do this, can you explain exactly what you need to buy for a single stage NX kit, i did notice the given piece was osmewhat small too.
Thanks,
Alex
Thanks,
Alex
This type of setup has much bigger internal passages than the NX-supplied T-fitting, and makes for a better installation - it will flow well enough for a 100-shot, if you feel the urge..
anything bigger than 100? I'm definetly feeling that urge, this is pretty much a drag only car, lol, POS i bought for 500 bucks to show off what nitrous can do, friends are a bunch of doubters
So this isn't such a pain ??
I strongly suggest that you learn how to apply nitrous to your engine - and the ground. Learn to manage a 75-shot in the quarter-mile first, then come back for the answers to the questions you have afterwards.
I run a 2-stage NX wet kit - with tricks - at 150-shot total. On an automatic. See one of my photos above.
Thanks for the info, but i dont need to know how to install it ive already done that...
So i need a brass T fitting with two smooth sides and a threaded bottom? and these are 1/8" inside diameter?
Alex
Alex
Alex
Alex
Originally Posted by t6378tp
hey have you run your car at the track yet with the nitrous
But i just got a '94 VE so that will become the track car in the next year and the nitrous will eventually get swapped to it, i hope to be running low 13's come this time next year.
Alex
This is what I have done for a single stage nitrous setup:
The reason you see two Tfittings is b/c I have a fuel pressure gauge also. And it was much cheaper to get two T-fittings instead of a 4 way cross fitting.
Here is a pic of my setup before adding the additional T-fitting for nitrous:
I got all those parts from Lowes and Home Depot. They both have the parts needed to do this. If for some reason they are temporarily out of stock, then you can get everything you need at www.mcmaster.com.
http://www.tuningmotorsports.com/pro...age=1&featured
I use this for my fuel needs.
Maximahappy, once I get my SSIM done.. we should meet up and get a race going once the track opens up. PIR will be up and running in February.
But yes we deffinately should, i cant wait to race on the new track even though traction wont be as good. I should be in the mid to low 13's this coming season and hopefully by the summer ill be in the 12's
I don't know if that fuel rail adapter will work with the VE30 but you could have a shop possibly fab you up one. Basically our fuel rails have open ends that are held on with a plate and two bolts. That goes on the end of the fuel then slap on the OEM plate and there you go, you can have fuel for your nitrous.
It's a very simple modification if you want to modify your stocker. Just cut a hole, have a shop weld on a AN flange and there ya' go.
Hell, I'm hoping to hit mid to low 13s with all the N/A **** I've done to this car. 12's with a 100 shot should be interesting..
It's a very simple modification if you want to modify your stocker. Just cut a hole, have a shop weld on a AN flange and there ya' go.Hell, I'm hoping to hit mid to low 13s with all the N/A **** I've done to this car. 12's with a 100 shot should be interesting..
VQ'ed
69
Aug 27, 2020 12:29 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
