MSD window switch (8956) wiring question
Old Apr 25, 2007 | 07:30 AM
absoundlab
I was just wondering if this looks right
Old Apr 25, 2007 | 07:47 AM
Maximahappy22's Avatar
This is what it should look like...
Old Apr 25, 2007 | 08:16 AM
absoundlab
well the thing is I want to hook up a wet nos system with full throttle activation on my friends 96 integra.
I have a fuel solenoid a nos solenoid and a msd window switch
Old Apr 25, 2007 | 06:28 PM
t6378tp's Avatar
Turbo 3.5
30 - battery
85 - ground from msd
86 - 12v switched source
87- niods
87a - nothing
you can also look on the 3rd page of my cardomain
Old Apr 26, 2007 | 06:00 AM
absoundlab
I have a 14 volt 30/40amp relay
Old Apr 26, 2007 | 07:17 AM
t6378tp's Avatar
Turbo 3.5
for my truck I am using a 25amp bosch relay
and the max a napa 30/40 relay part # ar274
Old Apr 26, 2007 | 08:13 AM
absoundlab
where does the yellow wire from the window switch go on the relay
Old Apr 26, 2007 | 09:32 AM
It goes to the noids... look at my diagram above...
Old Apr 26, 2007 | 12:12 PM
absoundlab
your thing shows the yellow wire going to the negative on the solenoids
Old Apr 26, 2007 | 05:51 PM
t6378tp's Avatar
Turbo 3.5
^ look at post # 4
you ground the niods to the car, the yellow ground from the msd goes to the ground on the relay and this is what tells the relay to give 12v to the niods
Old Apr 26, 2007 | 06:20 PM
IIRC i wired it to the noids...
Old Apr 26, 2007 | 07:09 PM
t6378tp's Avatar
Turbo 3.5
happy you have some rewiring to do, if you want to double check go on msd site they have diagrams of how to wire different nitrous setups
the ground from the msd is not good enough to be wired directly to the niod, yes it will work but it's not right
Old May 1, 2007 | 08:54 AM
absoundlab
I still can't seem to get this right. I tried wiring the msd window switch up the way t6378tp said to and still nothing. Also its a nos wet kit on a 96 integra. everything is mounted and I have the wet kit itself wired up like this.
I cant get the window switch to work. I tried it like this also and still nothing.
Old May 1, 2007 | 08:55 PM
t6378tp's Avatar
Turbo 3.5
the yellow wire from the msd goes to the green ground on the relay, check to see if the niods are working quickly touch them to your +/- on your battery to see if they click
the nitrous kit should be wired like the directions say, when adding the msd you're just taking the ground from the relay and running it to the msd instead of the car
also make sure the msd is installed correctly to check the msd take a light bulb connect it to a + source and run the - to the msd and set the msd to 1500 rpms rev the motor to 1500rpms and the light should either turn on or off depending on which wire you used
vingodine
45
May 21, 2016 12:46 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
mpbclutch33
Aug 21, 2015 06:09 AM
shaunkey1
Aug 18, 2015 10:09 PM
kjm900r
Aug 5, 2015 07:14 AM
