I need help mounting a micro switch on a 5th gen
Old May 14, 2007 | 08:54 AM
absoundlab
Has anyone mounted a micro switch on a 5th gen before? If so can you help me out here
Old May 14, 2007 | 04:45 PM
Jime's Avatar
If you are talking about a WOT switch, mount it under the gas pedal.
Old May 14, 2007 | 10:23 PM
absoundlab
I wanted to mount it by the tb
Old May 15, 2007 | 06:35 AM
Jime's Avatar
Old May 15, 2007 | 09:54 AM
absoundlab
thanx alot man. that looks like its going to be a complete pain in the a$$
Old May 24, 2007 | 06:09 PM
absoundlab
ya I was looking at it and that setup isnt going to work because thats on a
4th gen and the 5th gen dek is setup different.
Old Jun 15, 2007 | 01:42 PM
absoundlab
im still looking for someone with a 5th gen de-k motor that has a micro switch mounted to the throttle body
Old Jun 18, 2007 | 01:40 PM
killerVQ30DE's Avatar
FWIW - I'm going to go with an under pedal WOT swtich, just sorting it out now so will have it in soon - will post up for interests sake
Old Jun 18, 2007 | 02:34 PM
Jime's Avatar
Old Jun 18, 2007 | 03:53 PM
absoundlab
thank you jime i'll probably mount it under the pedal because there is really bo where to mount it by the throttle body.
Old Jun 18, 2007 | 04:51 PM
Originally Posted by Jime
SWEET! Thanks, i asked in the 4th Gen forums but the 5th gen delivered. I was wondering how I was going to mount the switch to the gas pedal stop - problem solved.
Why 2 switches Jime? Nitrous + DR?
Old Jun 18, 2007 | 06:01 PM
Jime's Avatar
Yes, that was back when I had the 2k2 and nitrous. I still have 2 nitrous kits but want to stay N/A for a while.
Old Jul 1, 2007 | 04:19 PM
absoundlab
alright I figured it out. I bought a nx micro switch and bracket and I modified it to work on a 5th gen dek motor.
here are the pics
Matt93SE
May 24, 2019 02:58 PM
vingodine
45
May 21, 2016 12:46 PM
Finkle
Sep 27, 2015 09:53 PM
Maximeltman
Aug 31, 2015 01:01 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
