Nozzle fitting adapter
Old Jun 8, 2007 | 06:03 AM
absoundlab
Is this nessecary
Old Jun 8, 2007 | 07:19 AM
grey99max's Avatar
LandShark has Cosworth
Originally Posted by absoundlab
Is this nessecary
Since you need to keep the nozzle aligned toward the TB, the adapter is there to provide support for the threads of the nozzle, even if the intake tube is thin metal. If your intake system had thick walls, I guess you could drill and tap the intake and screw the nozzle into the wall. You could possibly drill a hole into a thin intake tube and place two nuts on the nozzle, above and below the tube.
Do you have something sneaky in mind?
Old Jun 8, 2007 | 07:23 AM
absoundlab
nothing sneaky lol. I drilled and tapped my intake pipe and the nozzle fits tight. I was just wondering it its a better idea to use the Nozzle fitting adapter like a safety precaution.
grey99max can you send me some pictures of what rims you use and what tires you use at the track
Old Jun 8, 2007 | 07:58 AM
streetzlegend's Avatar
It is a better idea to get the adapter. Eventually your intake pipe thread is going to wear out and its not going to catch thread no more when you put in the nozzle. Its still going to serve the same function, but i really recommend you get the adapter make life easier.
Old Jun 8, 2007 | 04:18 PM
absoundlab
alright i'll pick one up
Old Jun 8, 2007 | 06:47 PM
NAS's Avatar
NAS
The adapter is a plus, not completely necessary but a little safer than just tapping the intake tube imo
Old Jun 8, 2007 | 09:40 PM
rockfordmaxII's Avatar
can you pick up the adapter at any autozone or advance?
Old Jun 9, 2007 | 08:01 AM
absoundlab
probably not. you can get it on ebay for about 10 dollars
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
Pied
Sep 26, 2015 03:29 PM
