fjo mini controller
Old Jun 9, 2007 | 05:53 AM
t6378tp's Avatar
Turbo 3.5
fjo mini controller
does anyone have a link to a wiring diagram for a wot switch the books yes to connect the input wire to the wot switch and the other lead of the switch to a ground
but when I tested it the nitrous did not activate
Old Jun 9, 2007 | 09:58 AM
t6378tp's Avatar
Turbo 3.5
ok for those who know about the mini controller
I checked the relay with the arming switch on and it's getting 12v
the blue wire is going to the niods ground and the ground for the controller to the car
but the green light is blicking is there anyway to reset the controller
ok I uploaded the controller with a new program to basicly make it a window switch, the yellow turns on at the pre-set rpm and turns off but the green light still blicks
Old Jun 10, 2007 | 09:38 AM
t6378tp's Avatar
Turbo 3.5
I talked to a tech in the ls1tech forum and they said the box needs to be reprogramed for a wot switch .. hopefully this works
Old Jun 18, 2007 | 06:07 PM
babymac's Avatar
BOOST 4 LIFE!
What are you up to??
Old Jun 18, 2007 | 07:26 PM
t6378tp's Avatar
Turbo 3.5
getting ready for the track
the controller is installed and works great just waiting for my axles still
Old Nov 27, 2007 | 02:31 PM
t6378tp's Avatar
Turbo 3.5
bump
tarun900
19
Dec 20, 2021 06:57 PM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
