Which wire to hook up to TPS for Zex
Old Jun 9, 2007 | 09:22 PM
Gle03Max's Avatar
Sorry Guys im searching and at a stand still....
I got the zex wet kit and I need to know where and which color and which one to hook the white tps wire too for the kit. ?
Old Jun 10, 2007 | 05:32 AM
Gle03Max's Avatar
Anyone.......I'm at a standstil here common =(
Old Jun 10, 2007 | 06:21 AM
absoundlab
the white wire goes to the tps.
Old Jun 10, 2007 | 06:22 AM
Gle03Max's Avatar
Where does the white tps wire from the zex management unit connect too is what I need to know.
Old Jun 10, 2007 | 06:42 AM
t6378tp's Avatar
Turbo 3.5
like he said the white zex wire goes to the white tps wire
Old Jun 10, 2007 | 06:44 AM
Gle03Max's Avatar
O ok. So the white wire is right on the throttle body right? There's a plug with six wires and the bottom right one is white. I jus wanna make sure I'm using the right hook up.
Old Jun 10, 2007 | 06:48 AM
t6378tp's Avatar
Turbo 3.5
correct on the tps there are 2 plugs, six wires total, and you want to tap the white wire think it's the middle wire on the plug closest to the drivers side would have to look at my car to make sure
I have to run to the store, I'll check than
Old Jun 10, 2007 | 06:52 AM
Gle03Max's Avatar
Alrite bro lemme know when you check thanks a lot guys.
Old Jun 10, 2007 | 08:05 AM
Gle03Max's Avatar
Old Jun 10, 2007 | 08:07 AM
Gle03Max's Avatar
Just to make sure....that's on the 3.5 right?
Also is it the tps near the throttle body?
Old Jun 10, 2007 | 09:36 AM
t6378tp's Avatar
Turbo 3.5
it's the middle wire on the plug closest to the passanger side
all six wires are differents colors but only 1 is white so it should not be hard to spot
oh and sorry I have a 3.0 but if you have a volt meter you can test the wire before you tap it
Old Jun 12, 2007 | 01:10 AM
2002AltimateV6's Avatar
It's the white wire for the 3.5 as well. And I suggest not using the vampire taps that came with the kit. Go with a pink crimp connector, much better connection with a lot less interference. Had problems with fuel-cut-off (or something similar to a rev-limiter) at 5k when using those vampire taps.
Old Jun 12, 2007 | 05:00 AM
Gle03Max's Avatar
I got everything working all set.
From what I understand from using the vantage pro and looking at a lot of wiring diagrams is that there are two input wires in the tps near tb. They both sense different rpms. One of these is the white wire and the other one is the one diagnally opposite I believe. Also there is a tps sensor on the gas pedal.
I tryed the white wire on the tb and got a wicked bad shot. I went back and tested it andf realized it had not been accurate.
I then went and used the one on the gas pedal and got the best signal and it works great!
Ps. I sautered everything.
Old Jun 12, 2007 | 03:53 PM
t6378tp's Avatar
Turbo 3.5
solder
Old Jun 12, 2007 | 04:19 PM
Gle03Max's Avatar
Lol I knew something didnt seem right
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
