Pulsing n2o
Old Apr 13, 2008 | 06:42 PM
Maximahappy22's Avatar
Pulsing n2o
Could the pulsing of a nitrous system be caused by a faulty relay?
I was testing my system today and my relay was clicking but the solenoid was not, so I am assuming that the relay is faulty. Any thoughts?
Alex.
Old Apr 13, 2008 | 10:10 PM
t6378tp's Avatar
Turbo 3.5
time to get out the voltmeter
Old Apr 14, 2008 | 06:52 PM
meh i dont have one, I just ended up buying a new relay. Hope it works!
Old Apr 14, 2008 | 07:00 PM
t6378tp's Avatar
Turbo 3.5
I would highly suggest getting a voltmeter, this is a great tool to have in general
Old Apr 15, 2008 | 08:59 AM
Aaron92SE's Avatar
NWP Engineering.com
If the relay is clicking, then it should be good. The easiest way to tell is to just swap in a good relay. Or you can put 12v to it and get your multimeter (that you should already own) and make sure you have continuity.
The only way to really diagnose this problem is with a multimeter. You can get them at Harbor Freight for $2.99. Or a decent one from Radioshack or Walmart for less than $20.
You need to make sure the solenoids are getting 12 volts. Also, just a thought, the solenoids will not activate when the bottle pressure is too high (ie, >1150psi).
Old Apr 15, 2008 | 11:01 AM
t6378tp's Avatar
Turbo 3.5
oh and to answer your question check your connections, if your getting 12v then your ground maybe bad. And if your ground is good then check your tps or wot switch
fyi solder all connections
Old Apr 21, 2008 | 09:57 PM
mastercater7's Avatar
VQ35 FTW
you shoulda bought a 4th gen alex
Old Apr 23, 2008 | 07:46 AM
UPDATE: So i figured out that i must have rewired the window switch incorrectly or something because the n2o sprays when I bypass the window switch.
Last night I went and tested it out to see if everthing is working fine. The first couple of times were on the freeway (3rd and 4th gear) I hit it and the car hesitated a little and then she moved like a bat outa hell. but when I tried using it from a stop I spun all of first and all of second and when i shifted to third the n2o was sputery. Like i would get power for about half a second then it would slow down again and repeat. What could cause this? My guess would be:
-Sticky n2o solenoid
-Stale n2o? (month or so old)
-Clogged n2o filter
-Something else?
Any help is appreciated.
Alex
Old Apr 23, 2008 | 07:54 AM
Aaron92SE's Avatar
NWP Engineering.com
-Clogged n2o filter
-Something else?
Alex
You don't have a wideband yet, do you? Check your plugs to see if you are running rich or lean.
Is your bottle pressure ok when it sputters?
What about fuel pressure? Do you have a fuel pressure gauge so you can read it at WOT? That would come in handy and only costs about $30 to rig up on the outside of the windshield.
If the nitrous sprays well in 1st and 2nd gear every single time, I'm guessing it's an air/fuel issue and not a solenoid issue.
MaximaDrvr
Aug 19, 2015 08:20 PM
Stikya
Aug 12, 2002 02:26 PM
JAIMECBR900
Aug 12, 2002 12:29 PM
JAIMECBR900
Aug 7, 2002 08:14 AM
