Nitrous Qs for my 5.5
Old Sep 27, 2008 | 08:49 PM
sparks03max's Avatar
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
I poked around on the nitrous forums trying to find some specific information, but some of the questions I have just aren't answered directly here, and it'd be nice to get a full post with good info.
Info on my car for the questions:
I recently uninstalled my AFC and i'm running around 10-10.5 AFR up top with full boltons.
I have intake/SSIM/spacers/headers-back full exhaust.
I'm looking to spray, but not upgrade my fuel system much right away, so that means a low shot hopefully 75 shot. Eventual goal of a 125-150 shot.
I'm pretty set on a NX wet kit that i can upgrade to a bigger shot later. I will definately be running a window switch set for 4k+ rpms. I don't plan on spraying off the line.
I know I need to change to copper plugs, 1 step colder.
I currently have no way to check my AFR
questions:
1. What's the max i should be able to safely spray without any fuel system mods or a wideband, just a wet kit?
2. What all would I need to safely run a 125 or 150 shot down the line?
Any other advice is welcome.
Old Sep 28, 2008 | 06:59 PM
SonicDust187's Avatar
You would need upgraded fuel pump for 125-150 shot. I would say that 75-100 is more then you will need. However if you are at 10 a/f just like you are then you will need to get smaller fuel jets for the nitrous because your a/f will be very rich with the nitrous.
Old Sep 28, 2008 | 07:54 PM
allblackmax96's Avatar
if you change your mind,im selling my zex kit in the general acc. classifieds, comes with almost everything.............
Old Sep 28, 2008 | 09:41 PM
ahh so no need of upgrades to fuel up to a 100 shot? That's nice...
I might have to put it on a dyno or get someone with a wideband to check my A/Fs to see what fuel jet gives me the best A/F while spraying. I'd rather be safe than sorry, though.
Old Sep 29, 2008 | 04:26 AM
TB.4L's Avatar
Buy a wideband to check afr.
Old Sep 29, 2008 | 09:06 AM
I made it very obvious that I'm looking to spend as little as possible on the initial installation and then begin to upgrade later as per this quoted question:
When I upgrade to spray a bigger shot, I will be getting a wideband, and fuel pump... as far as responses go those are the only 2 things I need.
Old Sep 29, 2008 | 09:07 AM
So can anybody confirm no need to upgrade fuel pump for a 100 shot?
Old Sep 29, 2008 | 03:21 PM
mastercater7's Avatar
VQ35 FTW
You will need to upgrade your fuel pump for a 100 shot. I have used NOS kits and Dynotune kits. I have also seen and helped install an NX kit. I must reccommend you buy the Dynotune kit. The Dynotune kit is the best in many ways. Power outputs, quality, and price. Give them a call and check out their website. They have some high quality controllers as well. You can run a 75 shot safely. I hope this helps.
Zack
Old Sep 29, 2008 | 07:16 PM
Zack
Great, good info. So 75 shot should be a thumbs up for now, and dynotune kit (i've looked at these and heard good things) over the NX. I guess when I upgrade fuel pump and get a wideband I'll just go with another 75 shot stage.
Old Sep 29, 2008 | 08:05 PM
VQ35 FTW
Yep, exactly. I have the dynotune kit, heater, purge, and blowdown tube. I received a faulty switch with the purge kit and they next day shipped me a new switch for free. Great customer service.
Zack
MAXSE5SPD
Sep 17, 2022 04:00 AM
Apr 16, 2020 05:15 AM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
