nwp plate yes or no?
Old Jul 18, 2009 | 11:20 AM
jr schultz's Avatar
For me I only care about how fast my car is on nitrous...And I only use nitrous at the track. Would the nwp block off plate benefit a nitrous set up or wouldn't it matter? I just got my 75whp jets and was wondering if I should get the $40 plate as well.
Old Jul 18, 2009 | 11:22 AM
Stormzusmc's Avatar
yes if your running a track set up it will help
youre running 14.2s with a 75 shot?
Old Jul 18, 2009 | 02:12 PM
jr schultz's Avatar
Its actually around a 50 shot. ZEX rates their kits at the crank. I also had real low bottle pressure at the time. I now have zex 100 shot jets( around 75 whp) that i will be installing. I'll be going back to the track this friday to hopefully greatly improve my times...Hopefully! Thanx for the reply.
Old Jul 18, 2009 | 02:49 PM
Stormzusmc's Avatar
make sure you have better plugs and injectors and what not
Old Jul 18, 2009 | 06:52 PM
sparks03max's Avatar
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
A fuel pump would be needed before injectors, and neither should be needed for a 75 shot.
You should be ok with 1 step colder copper plugs.
Old Jul 18, 2009 | 07:54 PM
jr schultz's Avatar
I have the right plugs for a 75 shot. My question is about the nwp plate. Anybody else confirm if it would really matter having this mod for a nitrous car?
Old Jul 18, 2009 | 09:20 PM
93altima's Avatar
Turbo 4th Gen
answer
Old Jul 19, 2009 | 06:18 AM
t6378tp's Avatar
Turbo 3.5
it's not required but will help and for 30 bucks just get it and make a pass with and out
I gained 4mph when I switched from a usim to a mevi and with my 3.5 trapped 110mph with a ssim and blockoff plate with a zex 100shot/nx 80shot
since you have the same motor and zex kit you can use this to compare with your own setup
Old Jul 19, 2009 | 09:02 AM
jr schultz's Avatar
Thanx
Old Jul 19, 2009 | 03:26 PM
krazy6's Avatar
The block off plate makes a nice difference, especially for $40.
Old Jul 19, 2009 | 06:19 PM
jr schultz's Avatar
I ordered one. Should be here in a few days so I can install it before my next track session. Block off plate and 75 shot should be a fun upgrade. Thanx for the replies guys.
Old Aug 17, 2009 | 01:45 PM
Juiced SE-R's Avatar
Good luck with this, keep us posted on the gains if any..
Old Aug 17, 2009 | 03:27 PM
jr schultz's Avatar
Waiting for cooler weather to determine any gains. The heat and humidity around here isn't helping anybody at the drag strip.
Old Aug 18, 2009 | 11:36 AM
Oh I already know, Oklahoma is no punk when it comes to being hot and humid so I feel your pain..
Old Aug 19, 2009 | 09:35 AM
nzelinsky's Avatar
Does the plate provide worthwhile benefit for NA cars?? I have an 02 with no nitrous and I was thinking about this, is it okay for DD cars?
Old Aug 19, 2009 | 12:19 PM
^ Yes and yes..
Old Aug 19, 2009 | 03:40 PM
allblackmax96's Avatar
this coming tuesday(hopefully) i will be doing some dyno test and tuning on my 5.5. ill be running my full ssim,then tune it with my safc,then run it with nitrous(75shot). then ill be switching to just a block off plate,tuning it with my safc,and running it with juice. ive been running the ssim and im kinda sick of the lack of low end power, so i might end up just running the block off plate,but we shall see what happens on the dyno...
Old Aug 19, 2009 | 07:53 PM
jr schultz's Avatar
Please keep us posted on those results. I'm very curious if you make more power with ssim+nitrous or just block off plate+ nitrous.
Old Aug 20, 2009 | 06:18 AM
I have my stock manifold on for now with the block off plate.. I normally run a 100shot with my Kinetix (which split along 2 diffrent weld but getting fixed) I went to the dyno yesterday to see what the diffrence was gonna be N/A and on spray between the two manifolds but the car was very rich and my tune from before was off, tried pulling some fuel out with my SAFCII but it started breaking up on the top end so it ended up being a waste of time due to fouled plugs.. I will get it fixed and go back so I will keep you guys posted on the results between the two manifolds.
In the meantime keep me updated on the SSIM vs block plate nitrous numbers if you don't mind..
Old Aug 20, 2009 | 10:02 AM
nzelinsky's Avatar
what is SSIM?
Old Aug 20, 2009 | 01:39 PM
ill prob be making a thread about the outcome, so you'll deff know what makes more power,more pratical power......
matts95max
Apr 23, 2025 10:44 AM
knight_yyz
Nov 1, 2015 01:34 PM
ricky7780
Sep 24, 2015 06:50 PM
