NX single stage limit?
Old Oct 16, 2009 | 02:15 PM
505max94se's Avatar
What is the largest shot I can spray with an NX wet single stage, single shark nozzle setup?
Old Oct 16, 2009 | 02:24 PM
krazy6's Avatar
Pretty sure you can go up to around 250hp. I am pretty sure the -4an line becomes the restriction around 300hp. It could be the nozzle too though.
The solenoids are good to around 400hp IIRC.
Old Oct 16, 2009 | 02:33 PM
505max94se's Avatar
I might have to get a progressive controller and some 200-250 shot jets!
Old Oct 17, 2009 | 08:43 AM
grey99max's Avatar
LandShark has Cosworth
The standard NX solenoids are rated at 175 HP. The -4AN bottle lines aren't good for even that much - not from the trunk, anyway.
To go higher, you will need 400 HP solenoids, a -6AN feed line from the bottle, a 5/16" fuel line tap, and -4AN couplers on both sides of the fuel solenoid. Also the nozzle lines need to be -4AN tubing with -4AN and -3AN connectors. An upgraded fuel filter is also needed, and your fuel pump better be a Walbro.
A single 100-shot is more than most cars can handle without most of the above mods. I was on a drag strip last night, launching with a 100-shot, and tire spin was crazy - a progressive controller is a good idea for most people - I won't use one. Too hard on solenoids...
Old Oct 18, 2009 | 02:57 PM
krazy6's Avatar
I thought all the NX kits came with the 400hp solenoids except the mainline.
Guess I was wrong lol.
Old Oct 19, 2009 | 06:49 AM
grey99max's Avatar
First rule of nitrous - don't assume anything. The import EFI kits are capable of 75-shot and not much more. Above that, it's mostly a plumbing problem. When you draw more fluid, you gotta have a larger pipe from the source (fuel or nitrous) to the nozzle. More fluid moving means more resistance in the lines. Larger fuel lines, bigger pump and larger nitrous lines are required for the larger shots - and the solenoids must be able to pass the volume for the shot.
I got very tired of dealing with restrictions, so I replaced everything with larger components. Everything.....
Old Oct 19, 2009 | 10:54 AM
505max94se's Avatar
Thanks for the info. I guess I'll stick with my 150 shot for now. Maybe I buy a mainline kit and run a completely separate 2nd stage when and if I decide I want more.
My -4an nitrous line seems to supply enough for the 150 shot because my afr is around 12.5:1.
Old Oct 19, 2009 | 12:54 PM
krazy6's Avatar
Two stages FTW!
Old Oct 19, 2009 | 01:01 PM
grey99max's Avatar
I'm sure you know what you're doing - but - when you hit the spray switch (however you do it) does the 150-shot throw you back in the seat and smoke your tires and break loose immediately?
'Cause if not, you have restrictions in your feed lines.... you can have reasonable A/F and have flow restrictions in the nitrous and fuel systems. Your power will just be reduced. Been there, done that.
Old Oct 19, 2009 | 01:36 PM
505max94se's Avatar
I have a DynoTune Two Stage RPM Window Switch to control my nitrous engagement. I have it set to spray WOT from 4k-6.5k rpm. Other than that, I just have a main arming switch. It works really well.
It DEFINITELY throws me back in the seat and I completely loose traction at speeds less than 70mph. Sometimes it spins the tires a little above 70 mph in 3rd gear. I have a functioning vlsd mt, 235/40-18 tires, and limiting straps.
I failed to mention that I made my nitrous line shorter because it's behind the driver's seat...
Old Oct 19, 2009 | 02:23 PM
grey99max's Avatar
That's a scary setup you have there - I like it.
It sounds like your setup is working pretty well, then. Had your car on a track yet? I can't spray more than a 100-shot in my first stage at the strip (second stage in 2nd and 3rd OK) - on the street with a first-stage 75-shot, no traction in first or second gears, and if I engage the 100-shot second stage in third, I fall off the highway.
Have you dynoed your car off and on nitrous? That's the only way to be sure at the higher shot levels - my dyno WHP is slightly better than one WHP for every one shot I spray (NX - you know what I mean) on up to 175-shot combined.
Bigger feed lines are better - in my experience. FWIW....
Old Oct 19, 2009 | 02:48 PM
505max94se's Avatar
Thanks.
I haven't been to the track yet... I actually went to the track yesterday, but it was closed due to rain. I was fully prepared with slicks and a bit of weight reduction. Funny thing is, it didn't rain all day and there was only a 10% chance of precipitation. Next weekend is my last chance to go to the track before the season is over.
I haven't dynoed my car, but I would like to. Before I bought my newer VE30, it was dynoed by the previous owner and it supposedly put down 205 whp na.
Old Oct 22, 2009 | 11:16 AM
BuiltnBoostedZ's Avatar
Here's an old dyno I have of a import efi kit. That's a little more than a 75 shot.
Old Oct 22, 2009 | 12:12 PM
505max94se's Avatar
It looks like 3 dyno runs were made here. Let me guess, first was an NA baseline, next was a 75 shot, and then the last was a 125-150 shot?? Did you ever make any 1/4 mile passes in the Z with a 125-150 shot?
Old Oct 22, 2009 | 12:30 PM
^no, never gotta chance. started to build the motor and add boost a few months after my nitrous tune. plans changed. Road racing > drag racing
She has been on Motorsport Ranch Houston though.
http://www.youtube.com/watch?v=cDR5lec4DwA
http://www.youtube.com/watch?v=Q1KglDDprG0
I'l be running her this weekend at a local drag event. Still have an intercooler spray bar, new nozzle, and carbonetics triple disc to put in before saturday. then we can tune for 22psi + 100 shot.
Old Oct 22, 2009 | 08:19 PM
grey99max's Avatar
So your 350Z only makes 225 HP when N/A? Hummm....
Old Oct 22, 2009 | 09:23 PM
505max94se's Avatar
iirc that's very normal for a stock Z
Old Oct 23, 2009 | 09:43 AM
grey99max's Avatar
I just noticed - that dyno sheet is FLYWHEEL power, not WHP. That's pretty puny for a 350Z, isn't it? 15% loss if it's a stick, 20% loss if it's an automatic.
Personally, I'm set for 430 WHP at the moment. That's 537 crank HP.....
Old Oct 23, 2009 | 09:48 AM
ignore the "flywheel". Its wheel hp. that dyno reads low. made about 230whp on i/e/h/tp/utec/plenum spacer (no spray).
and that dyno is really old. built on twins and spray now.
Old Oct 23, 2009 | 10:04 AM
grey99max's Avatar
OK - that makes more sense with a Z. Gonna do a dyno with your latest setup?
Old Oct 24, 2009 | 06:14 PM
2002AltimateV6's Avatar
Cool, another nitrous guy in WA. Where you located?
Old Oct 24, 2009 | 09:56 PM
505max94se's Avatar
NE Tacoma (Browns Point)
Old Oct 25, 2009 | 03:07 PM
Close, nice. I'm in Tacoma, near 72nd and Orchard. Basically borderline Lakewood.
litch
123
Jan 4, 2024 07:01 PM
BkGreen97
Apr 2, 2016 05:47 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
sliptap
Sep 30, 2015 05:57 AM
Max139617
Sep 29, 2015 06:44 PM
