The LED Light Picture Thread -Interior-
Old Aug 20, 2011 | 10:48 PM
  #121
schmellyfart's Avatar
Originally Posted by max_dreamer
lol, silly guy! you cant have more than one type of ac on at a time! he cant do feet only + head only + feet and head!
This ^
heres my super solder skills on the main window switch... looks like factory huh!?
Close. You used a bit too much solder, though. See how yours are more round/bubbly than the conical factory joints for the resistors and power supply?
Old Aug 21, 2011 | 02:27 PM
  #122
max_dreamer's Avatar
lol, yeah yeah! its close though. i like using alot so it has less chance of breaking loose, although it prolly never would. i had to use less on the surface mounts though, it was pretty tight spacing on those...
Old Aug 21, 2011 | 02:35 PM
  #123
tigersharkdude's Avatar
My lights in the AC have never worked. I didnt know they lit up accordingly. I thought that all of the lights were always on I guess. Silly me
Old Nov 16, 2011 | 05:19 PM
  #124
NHMAX603's Avatar
i look a little video of some of my leds the shifter u cant see to well in the video and i forgot to open the ashtray also the video does my gauges no justice i need a new climate contro mine has a huge crack in it but ive got other things to worry about
VIDEO
http://youtu.be/xOXHxKdafgs
Old Feb 4, 2012 | 08:38 PM
  #125
renots's Avatar
good lights everyone!! but i do have a question, i want to do my acc unit an cant figure out which size i need for it. i want the ones with a base already attached (plug an play) i kno the 98-99's use a t4 size but not sure if its the same for mine (96) i have looked an didnt find any solid answers
Old Feb 24, 2012 | 08:26 PM
  #126
Amerikaner83's Avatar
look in the 5th gen poll thread .. i believe it's the NEO3 twist-lock...check that thread out. Cjandura did it....
here:
http://forums.maxima.org/8372651-post154.html
youre welcome :-)
I am using that thread as well for my 4th gen lighting ideas...trying out 360* individual LEDs for the backlight of my ACC on my 99.
Old Feb 24, 2012 | 08:38 PM
  #127
renots's Avatar
He has the manual acc unit I have auto, the bulbs are different then mine. Thanks for the link tho.
Old Feb 24, 2012 | 08:45 PM
  #128
Buy three or 4 and see if they fit :-)
You'll only be out like 10 bucks if not
Old Feb 24, 2012 | 08:47 PM
  #129
or wait a couple days....I have several newo3-W coming to me, and if they don't fit my 99 manual control you can have 'em
Old Feb 24, 2012 | 09:26 PM
  #130
it's the neo3. according to this:
http://forums.maxima.org/4th-generat...bulb-info.html (post number 19)
Old Feb 25, 2012 | 10:28 AM
  #131
Number-Four's Avatar
and heres the top of the main switch
what voltage led's did you use and did you change the resistors also?
Old Feb 25, 2012 | 01:26 PM
  #132
Standard 3mm LEDs will suffice...and no resistors because you remove the factory LEDs and replace them with your LEDs. The resistors are already in the circuit.
Old Feb 25, 2012 | 02:46 PM
  #133
LED Vanity mirrors
FIN
bought them from here......31mm vanity, xenon white
http://www.wardenjp.com/stores/festoon.html
Old Feb 25, 2012 | 03:29 PM
  #134
Dude...that's sick!! Too bad my mirrors don't have the vanity lights...
Old Feb 25, 2012 | 04:43 PM
  #135
Looks good man.
Old Feb 25, 2012 | 09:22 PM
  #136
renots's Avatar
Rite on!! What color did you get? Shoot me a pm if they don't work for you.
An what size were the vanity mirror bulbs brad? I kno you mentioned 31mm, did these work? An at night are they too bright or just perfect? My wife already has said if they too bright I can't do em lol
Old Feb 25, 2012 | 09:39 PM
  #137
I got the cool white ones, I'll let you know if they fit or not.
Old Feb 26, 2012 | 06:55 AM
  #138
31mm
does she plan on driving down the road with the visor down and putting make up on ............at night?
Old Feb 26, 2012 | 12:25 PM
  #139
renots's Avatar
Lol she don't drive an is kinda sensitive to light, so if it's really bright she's blind for a while lol. An I don't wanna hear her ***** either haha
Old Feb 26, 2012 | 12:56 PM
  #140
She should be fine. I have photophobia , caused by NF2, it causes extreme sensitivity to lights
Old Feb 27, 2012 | 02:41 PM
  #141
CRUISE CONTROL LED SWITCH
For those of us that want to add LED to the cruise control switch, Below is some info you will need. I searched and didn't find any specific info, so I'm going to put this here.
The following applies specifically to my 99SE, I do not know if this will be the same as other years / trim levels.
The cruise control switch on the left side of the steering column has two bulbs in it. One is illuminated with a push of the switch to tell you cruise is ON (green square), the other bulb is illuminated when parking lights / headlights are on (backlighting). In my case, I wanted to change the backlight bulb since mine was out.
Taking the switch apart is no problem - two tabs and it's done. There are TWO bulbs, left and right. The one with the blue condom on it is on the right (for reference purposes). This is the backlighting bulb. When replalcing this with an LED, you need one 3mm LED and 470 Ohm resistor. Solder the resistor to the positive prong of the LED. I re-used both the blue condom and the rubber bulb housing, since I could not for the life of me find the correct way to orient the LED (which side is positive and which side is negative). So I bent the legs of my resistor / LED around the rubber housing same as the original bulb. This way, if I get polarity wrong I can just switch orientation and it's all good.
PROPER ORIENTATION of this LED setup: 12V is the OUTSIDE prong and ground is the INSIDE prong.
This is for the backlighting bulb ONLY. I did not change the bulb that illuminates when CC is turned on, so I can not speak to proper orientation of that.
I can take pics (and edit this post accordingly) if y'all want.
Old Feb 29, 2012 | 03:03 PM
  #142
The 3mm did work for me...however, they were really tight so I actually farked up the install and broke two of them. I ended up just soldering a resistor to a 5mm 360* component LED and re-using the original bulb base to get mine working.
Old Feb 29, 2012 | 06:28 PM
  #143
some pretty pictures:
(360* 5mm white component LED with 470 Ohm resistor for backlight)
(Blue indicator LEDs......I will sand these down though, HELLA bright right now)
(kept both standard orange LEDs for the defrost indicators)
Old Mar 2, 2012 | 09:00 PM
  #144
So the blue indicator LEDs were too blinding...very distracting at night. I ended up sanding the LED "bulbs" and going over them afterwards with a white paint pen (white out, basically). PERFECT. Visible during the day still, yet bright and blue at night. Look above at the pic with the 3 blue indicators, taken from my cell phone.
Now look at the pic below, also taken with my cell (same settings):
Much better, no?
Old Mar 4, 2012 | 11:11 AM
  #145
EmergesUnscathed's Avatar
I couldn't help but want to do some of what you guys are up to after seeing this thread. I generally like to keep it stock/OEM style inside and out, but the lighting in the Maxima is awful. I don't know if my bulbs were just old, but it seemed like they threw less light than any car I've had previously. Threw some SMD panels in the dome, map, trunk and door lights. I'm going to wire in two Cold Cathodes in the footwells that will be on only when the door panel lights are on. That way, when I drop something and turn on the dome light, I can actually see what's what down there.
Before:
After:
Threw a 48 SMD panel in the dome, one in the map, and one in the trunk (not pictured, but a vast improvement). Ordered 2 25 SMD panels for the doors, those are going in with the cold cathode tubes over the weekend.
Old Mar 4, 2012 | 01:30 PM
  #146
Love those SMD panels! I'm thinking of adding two more to my trunk, and mounting at an angle, wiring it to the other SMD panel I have in there so i'l have 3 separate SMD panels in the trunk...total illumination!!
Old Mar 4, 2012 | 05:23 PM
  #147
^ive got a 48 sitting here, just waiting on my car to get finished at the shop
Old Mar 4, 2012 | 09:07 PM
  #148
renots's Avatar
Dam I'm laggin on my LEDs!! Gonna feel awesome to be able to see all my buttons an dials, didn't even kno some lit up til recently!!
Looks good bro! Do you have any pics of how you soldered in the resistors? Money is tite ATM so I can't afford any oops' lol
Old Mar 4, 2012 | 11:18 PM
  #149
resistor gets soldered to the positive lead of the LED... and (at least on my 99) on the hazards, defrost, and dimmer switch, the ground lead is on the top of the switch, the positive is the bottom
On the Cruise switch, the positive is the outside, the ground is the inside. You can actually re-use the factory rubber bulb housing and the only soldering you do is the LED to resistor connection.
Old Mar 5, 2012 | 04:30 PM
  #150
...waiting at the mailbox for me today...
What sucks though...is I'm not sure if I want to do white or blue for the backlighting on my stock radio... white would match the cc backlighting above, while blue would match the shifter below!
What do you guys think? I have the white now, so I will install those up and see if I like it I guess... but my mind keeps straying to see what the blue would be like, especially @ night
Old Mar 5, 2012 | 04:50 PM
  #151
where did you get the org decals i've been looking for some
Old Mar 5, 2012 | 04:55 PM
  #152
Check the "general classifieds", there's a member on here selling them...erty67... 3 bucks each, 1 dollar shipping.
http://forums.maxima.org/general-max...-stickers.html
Old Mar 6, 2012 | 10:52 AM
  #153
99 Factory NON-Bose LED changeover
So this one is actually a bit more of a ***** than I expected it to be...not a "skip lunch and get it done" like I thought.
^^ This ^^ is what my factory PCB looks like. I circled the little bulbs (6 of them)...don't worry about the missing one top right corner, I removed that one already. These are little incandescent light bulbs, NOT LEDs as I had hoped. Just makes it a bit more time-consuming, that's all.
I have both 5mm 360* white LEDs as well as regular 30* 3mm white LEDs...I am not sure which ones to use. I'm going to try and use the 5mm 360* LEDs but if space is tight, I'll have to use the smaller ones. BUT a bit if good news: since these all have the little bulb condoms on them I won't have to worry about shoosing white or blue I can pull the little covers off if I want the change
Will edit this post with process as I go along.
EDIT 1:
Here is the thing with all the LEDs + resistors installed. VERY tight squeeze with the light diffuser when the faceplate goes on, but first, before the faceplate, we need to plug it in and make sure they work. The red on the VFD is just sharpie...I'm at work right now and I left my cello paper @ home.
...aaaand all lit up:
I removed the red sharpie since it didn't do well at all with regard to readability... will just throw cello paper on when I get home.
very carefully put the faceplate on and re-test with 9V battery to pwr and ground pins, all looks good, with a nice blue coloring to all the buttons... (No pic since I did this when I wasn't on a break - don't tell my boss)
ok, fine...quick pic:
Contrary to how it looks, all of the buttons are nice and evenly lit up in a shade of blue that's perfect! Can't wait to see it in my dark garage when I get home.
This is about as good as it's going to get taken here @ work... Never realized how light it actually is in here until I want it dark...I always thought it was pretty dark in my little corner...
Old Mar 7, 2012 | 08:33 PM
  #154
Finished the LED interior...got her all buttoned up again.
^^ Center console (Radio with white LEDs+blue bulb covers=nice faint blue backlighting)
^^This stuff is GREAT!!!!! For changing the clock color. None of that cello paper crap LOL
^^Blue filter from LEE Filter media shown above, in radio display
^^ Slightly darker blue filter from LEE media shown above, in clock.
Changed out shifter LED from the bright blue to a less-bright white. Goes better with the subtle-blue of the radio. Mee likey!
Old Mar 7, 2012 | 10:21 PM
  #155
That looks really good.
Edit: Did you use a regular or high temp filter?
Old Mar 7, 2012 | 10:55 PM
  #156
ShocknAwe's Avatar
Before:
After:
Great Idea with the foot light, functional not just for looks
Old Mar 8, 2012 | 04:09 AM
  #157
maxprivate's Avatar
Black Lion
Really nice work .. I remember I put LEDS in my Bose radio a few years ago then I upgraded my radio all together. Hours of work but worth the happy results when your done.
Old Mar 8, 2012 | 06:56 AM
  #158
Thanks, I used the refular ones, off the sample pack pictured above.
They're made for movie lights so I'm not worried about melting or anything...VFDs don't get all that hot. I only spend one dollar on the entire sample pack too, just went into a specialty lighting store local to me (that happens to be a reseller of LEE media) and told him what I was doing, and asked if he'd be cool with me buying the little sample pack. One dollar and I was out of there.
Old Mar 8, 2012 | 07:05 AM
  #159
thanks.
It was fun, and I couldn't stand the faint greenish output.
Old Mar 8, 2012 | 01:19 PM
  #160
I can't stay away from LEDs!
Just bought two 12SMD panels in BLUE to swap out for the 9SMD panels in WHITE i currently have in my door lights, and a 48SMD BLUE to swap out for the 24 or 36SMD panel in white I currently have for my dome light.
hehehe
Gonna take those white ones and do something nice for the trunk :-)
