The LED Light Picture Thread -Interior-
Old Jan 28, 2011 | 11:49 AM
  #41
defiance's Avatar
Looks great ! Thats the look im going for in the climate controls.
What color is that natural white ?
By the way What kinda bulbs are those so I know what to get ?
Old Jan 28, 2011 | 04:19 PM
  #42
TSoprano's Avatar
I've been wanting to convert my map and dome lights to the led boards for awhile..
Anyone have a good source for bright boards that drop right in without much modification??
Anyone use the boards they sell @ autozone and if so are they much brighter then stock??
Old Jan 28, 2011 | 05:14 PM
  #43
schmellyfart's Avatar
Originally Posted by black2000maxiSE
Just finished my climate control and door switches. Only got a pic of the climate before the battery on my camera died.
Did you use plug 'n' play leds or solder a bunch of them in? It looks really good, but the mismatched the led in the temperature slider kills it.
Old Jan 28, 2011 | 05:34 PM
  #44
maximus nismo's Avatar
I see my next "quickie" mod
Now I know some people solder in leds with resistors and some get premade units that just screw in. Which did you do and what are your sources. I.e., if you created them, where did you get your parts and if you bought them, from who?
Old Jan 31, 2011 | 06:38 PM
  #45
If I were to solder a resistor to a led for the climate control, what ohm resistor would need? I know there is a math calculation around here somewhere but I can't find it.
Can anyone give me the answer or post a link where I can find it?
Old Jan 31, 2011 | 07:03 PM
  #46
Gamble's Avatar
It's in my led thread.
Old Jan 31, 2011 | 09:51 PM
  #47
black2000maxiSE's Avatar
There all soldered in. I left all the stock led's in. I wanted the slider and selected functions to stand out so you only have to glance down to see what mode its on. I need to do the cluster as I have cheepo pepboys 194's in there and also a few random switches and the clock. I get all my leds from a local shop or vled.com
Old Feb 1, 2011 | 06:25 AM
  #48
pavelsmax's Avatar
http://lmgtfy.com/?q=resistor+to+use+with+led
Old Feb 21, 2011 | 10:06 AM
  #49
J2songz's Avatar
Originally Posted by defiance
Well I replace all my old gauge cluster bulbs with 5 way LEDS from superbriteleds.com and so far I love it. Now I want to LED the rest of
the interior out starting with the climate control cluster!
i like this
Old Feb 21, 2011 | 10:16 AM
  #50
How many leds did you end up using in there?
Old Feb 21, 2011 | 02:19 PM
  #51
defiance's Avatar
Yeah there not to bad but if you can wait a little longer for shipping you can get the same bulbs in a 5 pack for 9 bucks Shipped, on the bay.
Old Feb 21, 2011 | 06:56 PM
  #52
maxed_out_99's Avatar
just installed some white LEDs in my gauges, but 99s have a crappy setup. it doesnt look as nice as i had hoped. but i still love it
Old Feb 22, 2011 | 09:31 PM
  #53
I only replaced the 3 main lights that are in the plastic holders. I also sanded down the the led's to distribute the light evenly.
Old Feb 22, 2011 | 10:27 PM
  #54
Thanks.
Old Apr 5, 2011 | 07:26 PM
  #55
tigersharkdude's Avatar
the dome light is 2 12smd panels from ebay
and the doors both have a 7led T10 bulb, also from ebay
Old Apr 5, 2011 | 08:58 PM
  #56
maxsmooth's Avatar
^^That dome light is sweet, and I like your tweeters
Old Apr 6, 2011 | 01:27 PM
  #57
cashoit's Avatar
Yo shark man,
how did u LED the lights in? what size and did u get LEDs that come with the resistors? Im a Noob to teh LED game, but i wanna do my interior lights and the climate cluster
Old Apr 6, 2011 | 03:43 PM
  #58
the dome light and doors are plug and play. When you buy the dome off ebay, it comes with the connectors. Like those below, but I have 2 12 SMD panels that are wired together, when i bought them (from a different seller, and had different wire connectors), the connectors for the wires, and bulb adapters were bad, so i had to resolder everything and said F it and used both panels. I have a 36 coming in for the map light. The doors are just T10 Led bulbs
http://cgi.ebay.com/ebaymotors/Light...ht_2771wt_1165
Old Apr 13, 2011 | 11:41 AM
  #59
muniiitt's Avatar
Awesome
Old Apr 15, 2011 | 04:55 AM
  #60
96customax's Avatar
---Red Neons under dash, Red bulbs behind gauges "soon to be LED" Red LEDs in doors, Red bulb in shift indicator "soon to be LED" Red Trunk Light ---
I am doing the door switches/ climate controlls/ and trying to figure out a way to change the Clock color <-- did bright clock mod also
Old Apr 15, 2011 | 06:39 AM
  #61
pavelsmax's Avatar
Red Cellophane over the clock will turn it white, a few other layers will make it red, theres a thread on it around here somewhere.
Like the red theme, dome lights white leds??
Old Apr 16, 2011 | 05:43 PM
  #62
dencio's Avatar
Originally Posted by J2songz
i like this
nice set up.i have 4th gen maxima want kind of led did bought from superbright?
thanks
Old Apr 19, 2011 | 01:46 PM
  #63
dencio's Avatar
FYI The blue cluster isn't going in the car with the red CC
i have a 96 nissan maxima se and planning to replace the interior with led lights. how did you replace the hazard and defroster button lights?thanks in advance
Old Apr 19, 2011 | 02:06 PM
  #64
5th gen junkie's Avatar
HELP HELP HELP HELP HELP HELP HELP HELP HELP HELP HELP HELP HELP HELP HELP
I no this is a 4th gen tread but if ull dont mind can ull help me out on wht type or size of bulbs i need in a 2002 maxima? the 3 top light on the roof? and the 2 lower door panel bulbs?
Old Apr 19, 2011 | 02:38 PM
  #65
there is a 5th gen section for this but this should help you out
http://www.moodym.com/maxima/tech/maxbulbchart.html
Old Apr 19, 2011 | 02:44 PM
  #66
Got a new panel for the dome light. Its a 36 SMD panel
and I took the two panels I had in the dome and put them in the doors (I did this because one of my front 194/T10 Led's went out. And I needed a replacement asap
Old Apr 24, 2011 | 07:25 PM
  #67
maxima_driver's Avatar
how do i get into the keyring to swap out the light to an led? i keep getting stumped and forget about it.
Old Apr 24, 2011 | 08:29 PM
  #68
maxprivate's Avatar
Black Lion
Dam those are bright. I like them, I bet they are a lot brighter in person.
Old Apr 24, 2011 | 09:15 PM
  #69
The trim piece around the keyring just pops out.
Old May 4, 2011 | 04:10 PM
  #70
xskydivingdudex's Avatar
Not trying to ask a noob question bc i looked but couldnt find the exact answer... does anyone have a list of the bulbs needed to do an entire interior bulb swap? Im a big fan of the blue and so tht is wat will probably be in my car soon. Also wondered if the clock color could be changed out?
Old May 4, 2011 | 04:29 PM
  #71
JNCoRacer's Avatar
Just the tip.
Take some time and read the FAQ's.
Old Jun 21, 2011 | 10:59 PM
  #72
colombianmaxima's Avatar
i love the red in cc and cluster
Old Jun 30, 2011 | 12:43 PM
  #73
cashoit's Avatar
yo what LEDs are ppl using for the front dome manual lights? NOT the center dome.
I tried some t10s and they wouldnt fit properly. I was thinkin using t11s
Old Jun 30, 2011 | 02:02 PM
  #74
http://www.petah.org/maxima/hazard.htm
Old Jun 30, 2011 | 06:03 PM
  #75
TunerMaxima3000's Avatar
Wow there is some nice work in here, cudos boys! Haven't been in the 4th gen forum in a while. Here's my old 97 cluster, the first one I ever did, 5-6 years ago:
Defrost and hazard:
And my silly, not at all bright dome light. It looked cool though haha:
Old Jun 30, 2011 | 07:29 PM
  #76
Kevlo911's Avatar
Kevlo for President
http://forums.maxima.org/4th-generat...tons-pics.html
Old Jul 1, 2011 | 09:06 AM
  #77
So cheap to buy decent premade ones now-a-days though. I sell them as well as another member on here, plug and play with fantastic results.
P.S. and OT, I'm still madly in love with those tailights Kev, I wish I had the time to do my 5th, I don't think anyone's done it on the 5th yet.
Old Jul 1, 2011 | 10:16 AM
  #78
yep I did my dome/map/doors for ~$12. All ebay stuff from china. No problems out of any of the SMD panels or SMD bulbs
Old Jul 7, 2011 | 08:36 PM
  #79
Oh and here is a couple sneak peek shots of 95maxrider's Gear that I'm doing.
96 Infiniti I30
Gauge Cluster:
Master Switch:
ACC, with custom Red and Blue temp buttons:
Old Jul 7, 2011 | 09:05 PM
  #80
maxprivate's Avatar
Black Lion
96 Infiniti I30
Gauge Cluster:
Master Switch:
That looks really good. IMO the 4th gen gauges only look good when you use one single color LED. especially the non digital gauges. I tried red for needles and Blue for cluster and they looked purplish in the center of the clusters.
Where did you get the LEDs for the window switches? I like white the color and brightness, you have a link to where you purchased them? I never got around to doing my windows switches.
