starter bolt, need some tips
The bigger bolt on the starter is being a ****!!! any tricks on breaking it loose? its the original starter (98,110k).....i thought of starting the car for 2 minutes before i started but i gave it the benefit of the doubt......im afraid of breaking the bolt, if i do im screwed! any one ever break the bolt on the starter?
any tips, tricks would be greatly appreciated!
tx
tx
It's gonna go "SNAP!!!" when it finally lets loose. You will probably have a mild anxiety attack when this happens the first time thinking you sheared it off, at least I did. You will need a cheater pipe on your ratchet, a breaker bar or a long 1/2" drive ratchet. I'd stay with a 1/2" drive here as a 3/8" probably won't get it.
i know my luck, and i will go down in history as the only one to ever break a starter bolt on the 4th gen....do u think maybe running it for 5 mins will help?
I am not sure how running the car for 5 minutes will help. Soak with PB blaster and then try to take it off with 1/2 inch ratchet and 6 point socket. If you need get a breaker bar or a pipe over the ratchet.
theyre usually tight, ive never broken one. just get yourself a 15 inch breaker bar ratchet, one had on the end of the ratchet then bump that hand with the other in a quick snap and itll let go
dont screw around with a little ratchet forever, that point you risk rounding the bolt then its a nightmare. one quick hit is all you need
never greased a starter before...allways just changed em
litch
123
Jan 4, 2024 07:01 PM
RealityCheck
Oct 2, 2015 06:34 PM
maxima297
Sep 30, 2015 03:32 PM
