Gas pedal hack for ae pedal fitment
I'm not familiar with the AE pedal or the plate you mean. There's not too much to a pedal though. If yours doesn't have the plate then it should be fine.
Can you post a pic of the pedal and the plate?
if you see behind the pedal pad, there is a metal plate welded in 2 spots.
let me know what you think.
I'm not sure if this is going to help you out or not, but I used this thread when I installed the AE pedals in the max.
https://maxima.org/forums/5th-genera...ml#post7287567
thanks for the response.
thanks for the response man. I will definitely cut it off to get the AE pedal in. I've read on the threads that I can roll up some electrical tape around the pedal rod to keep the pedal snug and from moving.
02whitemaximase
Dec 5, 2016 05:45 PM
