Anyone tries a Turbo XS H BOV?
Old Dec 9, 2002 | 11:20 AM
Canuck's Avatar
Just wondering if anyone has any experience with a Turbo XS Tyoe H BOV and if they would recomend it or not.
Old Dec 9, 2002 | 09:43 PM
BippuBenji's Avatar
Hmm, I haven't heard of anyone using the TurboXS one. Most people pretty muc go with the Blitz since it bolts right on, I decided to remove my Blitz and get the Greddy Type-S, definitely worth it. I was thinking of the HKS Super-Sequential, but I think I'll try it later in the Spring. Is there a particular reason yor wondering aobut the TurboXS?
Old Dec 9, 2002 | 09:56 PM
Tanman's Avatar
I remember reading Sprintmax saying he'd never use a Turbo XS product. I guess that means they suck, or he has a personal issue with the company.
Old Dec 10, 2002 | 01:57 PM
Canuck's Avatar
I know someone with it on his 1.8t and it sounds really good.
Old Dec 10, 2002 | 03:58 PM
hlh0501's Avatar
Turbo XS typeH they say on their website, for cars boosting over 10psi....
Old Dec 10, 2002 | 04:02 PM
Canuck's Avatar
I realized that just before I read your email. I think I will just go with the Apexi.
By the way youve got mail.
Old Dec 10, 2002 | 04:09 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
I dunno why turbo XS seems to get a bad rap fo being "cheap" or an "imitator" because thats HARDLY the case!!!
My buddy has a Turbo XS type H on his Eclipse, no probs what so ever for the past 2 years. sounds nice, a good "woooosh", no whistle and no "hurricane" sound....I reccomend it.
Old Dec 10, 2002 | 04:25 PM
Canuck's Avatar
The ten psi minimum is my worry since I don't plan on running that high.
And it does sound great!!
Old Dec 10, 2002 | 05:26 PM
BippuBenji's Avatar
Here's a link to some sound clip I heard before I purchased the Greddy. Hope this helps.
BOV Clips
Old Dec 10, 2002 | 07:15 PM
PCGuRu2K's Avatar
Anyone know where I can get the HKS one for cheap? I'm thinking of getting one to replace my Blitz..
Old Dec 10, 2002 | 07:24 PM
Tanman's Avatar
Try eBay?
Old Dec 10, 2002 | 07:59 PM
PCGuRu2K's Avatar
Try eBay?
Yeah I saw a few on there.. Pretty good prices too.. They have flanges in the size of 60mm, 50mm, 55mm.. Do you know which size the blitz flange was? 60mm?
Old Dec 10, 2002 | 09:39 PM
Tanman's Avatar
Sorry, I went with Greddy. I think those sizes correspond to the size of the hole on the charge pipe after you cut off the Bosch valve stem. Anyone know for sure?
Old Dec 11, 2002 | 12:50 AM
BigDogJonx's Avatar
Man all this BOV talk is confusing the hell out of me. I want one but in no way want to weld it on. There has to be a way to get one that just bolts upto the charged pipe by a rubber hose like the stock bosch one is.
Dixit
Old Dec 11, 2002 | 06:35 AM
Tanman's Avatar
Dixit
Check out my BOV stall thread, PCguru2k installed his like you're wanting. He connected the flange to the BOV, then ran a rubber hose from the flange to the inlet on the charge pipe (where the Bosch is normally mounted). To fix the problem with stalling, you could then run a rubber hose from the BOV outlet to the intake pipe so that the released air can recycle back into the system (like Maxboost00 did). I'm not currently having a stall problem with my Greddy BOV, but that's because it's adjusted down pretty far. Unfortunately, that means that the meager 6 psi of boost my stock setup is making is barely enough to make the BOV open and the sound is not very pronounced. Hopefully when I go to a 3.125" pulley, enough boost will be produced to make the BOV sound good.
Old Dec 12, 2002 | 03:14 AM
PCGuRu2K's Avatar
Yeap.. I would def. recommend doing it this way.. But I didn't have to run a hose back uto the system. I just plugged the ther other nipple on the other pipe.. I had initial stall problems but then I just adjusted the screw on the bov... I'm planning on getting an HKS so if anyones interested in the Blitz BOV with Flange PM Me
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
BkGreen97
Apr 2, 2016 05:47 AM
09maxshawn11
Sep 30, 2015 10:28 AM
Keyno McMike
Sep 21, 2015 07:18 AM
