****en Check Engine light is on!!
Old Dec 17, 2002 | 07:26 PM
RBa's Avatar
RBa
Nothing more to say.. I'm just plain ****ed off and frustrated!!!!
Stupid check engine light!!...
Who else had this problem? Did you find out what it was?
Old Dec 17, 2002 | 07:39 PM
190hpKiLLA's Avatar
Granny Driven
Re: ****en Check Engine light is on!!
Why not do the self diagnostic test?? and find out?
Old Dec 17, 2002 | 10:55 PM
RBa's Avatar
RBa
Re: Re: ****en Check Engine light is on!!
I will.. First thing tomm..
Old Dec 18, 2002 | 10:43 PM
RBa's Avatar
RBa
Re: Re: Re: ****en Check Engine light is on!!
I got it diagnosed today. It turns out that one of the VI soleniods was bad.. Here's a pic..
Old Dec 19, 2002 | 06:53 AM
PCGuRu2K's Avatar
Re: Re: Re: Re: ****en Check Engine light is on!!
So that means you gotta replace that whole piece now? Could it be because you didn't have it plugged?
Old Dec 19, 2002 | 07:27 AM
190hpKiLLA's Avatar
Granny Driven
Re: Re: Re: Re: Re: ****en Check Engine light is on!!
RBA tell us what happened cause it makes me think twice before going to Jeff's.
Old Dec 19, 2002 | 08:00 AM
PCGuRu2K's Avatar
Re: Re: Re: Re: Re: Re: ****en Check Engine light is on!!
Why would you think twice about it? Jeff did my SC install and it was fine..
Old Dec 19, 2002 | 08:01 AM
Jer's Avatar
Jer
Just in case it helps someone else down the road; mine went on after starting up with the s/c and went away the moment I started up with the 1-step colder copper plugs.
Old Dec 19, 2002 | 10:19 AM
RBa's Avatar
RBa
Yeah.. I gotta replace that solenoid.. It was always plugged. Jeff just didn't hook up the hose leading to the VI... Hence the CEL!!..
Old Dec 19, 2002 | 08:00 PM
RBa's Avatar
RBa
Re: Re: Re: Re: Re: Re: Re: ****en Check Engine light is on!!
LoL.. This is why it's called home of the lemmings..
Old Dec 21, 2002 | 03:37 PM
nymjayjay's Avatar
Old Dec 23, 2002 | 08:19 PM
hooktup98SE's Avatar
hey bro... should not be a problem... i had this exact same problem last month... so i got it diag'ed at Nissan... it came up with two codes... one for cylinder misfire(which is very occasional)... and one for running lean... which from what i understand just happens when you are supercharged... it needs to be tuned more properly... but it's nothing that will kill your engine anytime soon... sometimes because of how much air is being blasted into the intake, not enough fuel is being added so the computer tells the engine to push more fuel and it may be too much at times...but hey if anyone knows more or something i don't know about this than by all means let a brotha know.... i am just going by what i was told...
Old Dec 24, 2002 | 02:22 AM
RBa's Avatar
RBa
I'll be sure to watch out for that later.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
