Is my belt too tight? See pic
Old Dec 17, 2002 | 09:28 PM
BlackCat's Avatar
RIP '98 Maxima SE
After reading that the tensioner pulley should be tightened AFTER the tensioner nut has been adjusted I shot this pic after readjusting it to see if everyone else's angle is similar.
http://images.cardomain.com/installs...57_15_full.jpg
Hopefully this will get rid of my annoying slipping belt noise.
Old Dec 17, 2002 | 11:02 PM
Chunger's Avatar
My other car is a Hybrid
I've never done the deflection test that way...
I always twisted it until it is about 90 degrees (ALONG the length)
Old Dec 18, 2002 | 08:04 AM
BlackCat's Avatar
RIP '98 Maxima SE
Well, after I shot that pic I put everything back together and this morning I didn't get one squeal out of the belt. Turning on the heater fan also didn't squeal so that means I finally got it right.
So there you go, boys and girls...loosen the tensioner pulley first before adjusting the belt tensioner.
Old Dec 18, 2002 | 08:26 AM
JAY25's Avatar
when you rev up your RPMS past 5900 if you dont hear a squeal your good.
Old Dec 18, 2002 | 09:20 AM
BlackCat's Avatar
RIP '98 Maxima SE
I'll have to try that tonight!
Old Dec 18, 2002 | 03:45 PM
BigDogJonx's Avatar
Yeap. I found out that as well the hard way.
Old Dec 18, 2002 | 04:01 PM
BlackCat's Avatar
RIP '98 Maxima SE
The more that I think about it I think that may have contributed to my early blower bearing failure. I never thought to loosen the tensioner pulley every time I tightened the belt tensioner.
Old Dec 20, 2002 | 05:41 PM
maxxboost00's Avatar
What do u mean loosen the tensioner pulley first? So, first, tighten the tensioner and then tighten the pulley afterwards?
~AC
Old Dec 20, 2002 | 06:46 PM
Chunger's Avatar
~AC
The bolt/stud that goes through the pulley has a "LOCK" nut. It must be loosened BEFORE attempting to "ADJUST" the tension, which is a separate part. If you don't and you force it, you will have to buy a new assembly.
Old Dec 25, 2002 | 09:10 PM
BlackCat's Avatar
RIP '98 Maxima SE
Dang! Still fiddling with the belt tension. The car while in park sounds ok but while at the light I get that stupid ratchety vibration.
So you test the belt by twisting it lengthwise to no more than 90 degrees?
I was using that belt dressing but that just makes the belt really tacky to the touch.
Old Dec 26, 2002 | 09:16 PM
BlackCat's Avatar
RIP '98 Maxima SE
Well, after fiddling with the tension I think I got it just right. Too tight and the blower bearings start to rattle in protest. Too loose and the belt will slip and squeal and the belt will vibrate like a rubber band between the 3.33" pulley and the tensioner pulley. I had to do trial and error adjustments and road tests to find that right balance. I wound up very close to the original tension I had in my pic.
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
bigfrank
Oct 1, 2015 12:51 PM
homewrecker
Sep 24, 2015 07:01 PM
