supercharger thermostat housing install question
Old Dec 18, 2002 | 04:50 AM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
I'm about to swap out the thermostat/housing on the right side of the motor..... I wanted to know if I had to actually drain the coolant from the radiator or if I could just swap the hose and thermostat quickly...
Old Dec 18, 2002 | 07:11 AM
Stephen Max's Avatar
Re: supercharger thermostat housing install question
I guess if you're fast enough you won't lose too much, but you can avoid a mess by just taking a little extra time to drain the system.
Old Dec 18, 2002 | 08:00 AM
turbomax97's Avatar
Re: Re: supercharger thermostat housing install question
yeah i'll just drain it, it probably needs to be anyway...now do i just drain the radiator or do i have to undo the bolts that drains the cylinders
Old Dec 18, 2002 | 08:12 AM
Re: Re: Re: supercharger thermostat housing install question
Somebody else will have to answer this. I've never drained the cooling system of my Maxima, and my FSM is at home.
However, with every other car I've owned all you had to do was open the petcock at the bottom of the radiator.
Old Dec 18, 2002 | 08:14 AM
delio's Avatar
Just drain the radiator... squeeze each of the lines a few times, that will get the majority of it out. You will be OK.
Old Dec 18, 2002 | 08:38 AM
turbomax97's Avatar
Re: Re: Re: Re: supercharger thermostat housing install question
thanks delio
Old Dec 18, 2002 | 09:35 AM
Cumalot's Avatar
Yes you definitely have to drain the radiator fluid first. If you don't drain it, fluid will spill everywhere.
max_speed97
Aug 26, 2015 07:46 PM
spidgeon
Aug 18, 2015 05:46 AM
acw
Aug 13, 2015 12:50 AM
acw
Aug 7, 2015 04:20 PM
MikesChevelle
Aug 6, 2015 11:36 AM
