View Poll Results: Would there be problems with installing boost gauge on NA car?
No problems to consider
50.00%
Problems would occur
25.00%
Can't you wait a couple weeks at least?
25.00%
Voters: 4. You may not vote on this poll
Boost gauge readings (Poll)
Old Jan 8, 2003 | 02:20 PM
WizzaMax's Avatar
I am trying to play devil's advocate and guess what if anything will be hurt by installing the boost gauge inline off the manifold prior to the SC ...as well what would the readings be...I understand the concensus is the HG when not boosting and the lbs of boost when it is on.
Old Jan 8, 2003 | 02:28 PM
iansw's Avatar
Re: Boost gauge readings (Poll)
When NA, you will never boost. you will always be invacuum, or at WOT, you will be at "0"
That's the way I understand it.
As far as problems, - it's just a gauge and hose - it can't cause any problems.
Old Jan 8, 2003 | 02:46 PM
Chunger's Avatar
My other car is a Hybrid
..installing the boost gauge inline off the manifold prior to the SC ...
I don't even think that is possible...
As long as the vacuum/boost source is after the THROTTLE BODY, you should be fine.
Old Jan 8, 2003 | 11:49 PM
WizzaMax's Avatar
Can I ask for a member with a Boost gauge to take a detailed picture of the area by the TB to show me what a connection might look like? I have a new gauge and want to relate it to the cars layout...thanks in advance.
Old Jan 9, 2003 | 05:28 AM
Confused's Avatar
Permanent Maxima.org Resident
look for the oem fuel pressure regulator... see the hose on the bottom going towards the floor? that is where most people tap in.
Old Jan 9, 2003 | 08:06 AM
WizzaMax's Avatar
thanks but the location was not the issue, it is seeing to actual connection...mostly to look at the actual fitting used to connect to hoses...and I was going to use the port just behind and past the TB.
Old Jan 9, 2003 | 09:40 AM
Chunger's Avatar
I just tapped using a "T" from the line going to the Blue Vortech FMU...
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
maxinout93
Oct 31, 2015 02:04 AM
MichMaxFan
Sep 30, 2015 09:18 AM
