More fuel pressure than expected
Yet another fuel pressure related thread.
I installed the Vortech FMU over the weekend and tested it by creating boost with a Mityvac (yes, you can use it to blow as well as suck). At 2 psi of boost, my fuel pressure gauge registered 50 psi, and at 6.5 psi of boost, I got 95 psi FP. Now (95-50)/(6.5-2) = 45/4.5 = 10. So apparently Vortech sent me a 10:1 disk when I ordered an 8:1. Or possibly, there is enough error in my gauges to show a false 10:1 reading.
Is it possible that the high pressure Walbro pump I installed affects the delivery rate of the FMU?
Re: More fuel pressure than expected
Stephen,
If you want to be sure, I'd call Vortech and ask them
what size diaphram you need in the FMU to get 8:1.
There are no part numbers on the diaphram so the only
way to tell is to measure the diameter of the diaphram.
When I called Vortech they were pretty helpful
and disassembling the FMU to get to the disc/diaphram
is pretty easy.
-Victor
(PS I did this before but regretfully forgot the right
diameter)
is pretty easy.
-Victor
diameter)
Originally posted by vbxmaxima
Stephen,
is pretty easy.
-Victor
diameter)
Stephen,
is pretty easy.
-Victor
diameter)
jmlee44
Oct 2, 2022 02:13 PM
Forge277
Jun 13, 2016 09:26 PM
Unclejunebug
Apr 2, 2016 05:42 AM
