SC setup guage ?
SC setup guage ?
I am getting geared up to install my SC next week. What guages do you recommend? I think boost, EGT & Fuel Preasure. Where should I get them and who has the best prices.
Also does anyone make all 3 in digital?
Tahnks for the help.
Originally posted by BlackCat
People here recommended Boost and EGT as the ones to start off with.
For sure Get an EGT guage, and fuel pressure... Boost is a good guage, not that you'll overboost, but u can check your work since it reads vacuum etc..
Give us a price limit and we can help you better, the prices of guage vary greatly, form 50 bucks a guage, to a few bills.
Originally posted by seximagtr
Get a Mechanical Boost guage, and there's MANY different electrical egt,fp etc type of guages... digital, I haven't seen too many..
Originally posted by LatinMax
reliablity is more than important than cost. Don't get me wrong I don't want to spend a fortune on it, but just for pretty won't work. I there is a need for these guages I want it to be accurate.
If you want a good af guage, people say the Greddy af guage is a good setup because it uses it's own o2 sensor.
stick with quality guages then, for boost, anything works realy.. it's not like you're going to overboost. For the other types, the actauly safety guages, stick with quality brands i.e. Apexi, Greddy, HKS, Blitz.. stay away from autometer... Autometer is cheap, and isn't all that accurate.. Those guages i mentioned are a little on the higher side of the price line, but imo, worth it.
Where do I get them? and how much?
I have boost/EGT/tranny temp. Tranny temp gauge is just something that I use to eliminate heat as a reason of tranny failure.
EGT - I would recommand A'pexi electronic gauge with warning/peak/memory. Those looks really nice at night. But the price is kinda high, about 240. If you want a cheaper one, Greddy has the same thing but it is not indeglo like A'pexi.
Boost - I recommand a mechanical boost gauge in PSI format. So it is easier to follow with your pulley setting. All the warning feature on boost gauge is not necessary.....because you will not overboost with the SC.
happy shopping....get the EGT to start with.
I still am looking to see who has a good price. This site was given to me and has been the cheapest so far. Do you guys have any other site with good prices.
Oh, Autometer is not a choice. Thanks for the info thus far.
try optauto.com....they also have a lot of selection. but it is a bit expensive than gruppe-s.
Originally posted by Mike H.
Why do you not recommend autometer? I was planning on getting a boost gauge and egt from them this week and you have me thinking now. Can you please explain why they are not accurate? Thanks.
Autometer is alright for the price, but I happened to get them with the kit and they do their job ok, but if I didn't have a cash limit, I'd go all out and get the greddy af guage, whatever boost guage, and an apexi fp..
Well, sometimes fp is off by a few psi... and my egt's seem a little bit low (granted I'm tapped into a spot further down the exhaust stream)..
On the other hand, my autometer boost gauge is indicating about 1 psi too high when calibrated against a high quality pressure gauge.
What are your thoughts on VDO and Omori gauges? The reason I'm not going with the greddy ones is because I want something to blend in with the interior, hence the autometer gauges.
James92SE
142
Jan 2, 2024 09:23 AM
Apr 16, 2020 05:15 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
