How to swap pulley?
Old Feb 8, 2003 | 05:09 PM
WizzaMax's Avatar
How to swap pulley?
I heard one person say to swap to a different size pulley, it obviously has to be removed but the pulley must be pressed from the housing...as well the smaller Vortech pulley I bought did not come with any bearings/race/nothing inside...
I have seen lots of instructions on the SC kits but is swapping the pulley really that difficult...I had hoped it would be as easy as removing the blower, unbolting the hex-head bolt in the drive pulley and removing it from housing...
any info will be appreciated.
Old Feb 8, 2003 | 07:47 PM
delio's Avatar
Tracy,
No pressing
Just take the old pulley off and slide the new pully on...
Old Feb 8, 2003 | 09:44 PM
Craig Mack's Avatar
All YOUR grammer belong to me
Goin with the 2.87 Tracy?
Old Feb 8, 2003 | 11:38 PM
Chunger's Avatar
My other car is a Hybrid
Removing the S/C from the bracket can be a pain... use impact tools... if you don't you'll strip the allen screws.
Old Feb 9, 2003 | 12:42 AM
BigDogJonx's Avatar
Man I BENT two of my Allen wrenches from my Craftsman set. Litterally bent them. Good thing for Sears, bring it in, get it replaced.
Dixit
Old Feb 9, 2003 | 08:23 AM
WizzaMax's Avatar
soon...I am going to swap when I get the right standoff bolts and can actually bolt it up completely secure.
Old Feb 9, 2003 | 06:42 PM
JAY25's Avatar
hmmm interesting, You can use the 3/8 allen sockets with the 3/8 ratchet. You will need a piece of fence pipe to break them loose. Just slide the fence pipe all the way down on the socket and then slowly press down to loosen them up. If you snap the allen socket take the plate with you to Sears and break them loose in the parking lot. I went thru 4 allen sockets on the last bolt & it finally came off. One more thing do not use a 1/2 to 3/8 adapter you will snap the allen sockets like pencils trying to use a 1/2 breaker bar etc..
Old Feb 9, 2003 | 07:19 PM
WizzaMax's Avatar
thanks I may try that...seemed of the allen wrenches I had that fit , the 5.5mm was the one...for the small one...it torqued so bad I cut the l shaped part in half and it actually fit in the crevice nicely for the tensioner pulley bottom hex-head bolt...also number 18...
Old Feb 9, 2003 | 07:38 PM
JAY25's Avatar
there you go you remodified it for your needs.
Are we Marines or what? we should have joined the Air Force
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
ef9
Oct 4, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
