Did Stillen crush bend this?
Originally posted by Y2KevSE
My setup has the ability to start boost at a little before 2000 (in 5th gear if that makes a difference). I finally had a chance to see this yesterday in slow traffic... didn't get a chance to try for peak boost since there was too much traffic.
Quit rubbin' it in.
Originally posted by Craig Mack
I didn't ask for specs of your Turbo, Mr. I'm-better-then the-Supercharged-Guys. :mad :-p
Quit rubbin' it in. :mad
Remember this... you can walk away from the TC guy at low RPMs. By the time he's starting to pull on you, cut over into his lane and flash your hazards.
How would a linear boosted SC Max pull on a "roots" type turbo Max at low RPM?? Are you just trying to make me feel better Kevish, or is their truth behind this?
I'm talking LOW RPM... make sure he isn't rolling above 3k when both of you start... hard to do that though.
BTW, I'm kidding about pulling in his lane and flashing your hazards... it is VERY dangerous.
Remember this... you can walk away from the TC guy at low RPMs. By the time he's starting to pull on you, cut over into his lane and flash your hazards. :naughty :
I totally understand, you get in front of them, slow down, and force them to go back to low rpm, then gun it again.
j/k
I get ~26mpg. I drive ~85 miles per day round trip to work and back. Got 420 miles out of my last tank.
I got the silicone hose from
http://www.bakerprecision.com/silicone.htm
Originally posted by MardiGrasMax
[B]I get ~26mpg.
[B]I get ~26mpg.
You've gotta be sh!ttin' me....seriously....I mean....are you serious!?
How is it that you are getting better MPG then I do and your running almost twice the boost? What's your fuel pressure at idle? BTW, how many miles is on your car? I've always wanted to know that. I'm hitting the 77k mile-mark soon and people think that's high.
55k
Keep in mind 75% of my driving is at highway speeds.
55k
Originally posted by ejj
Thanks. Did you just use a 90* elbow, straight length, and a short length of tube in between? All 3" I assume?
Hes just a small tube in between.
I also but a thin piece of rubber hose cut open between the headlight harness and the hose becuase it rubs and the extra piece is a isolator.
Yes 3" 90* elbow. The blower out put side is 2.75"OD and 2.5"ID. I went 3" cause I thought i needed it, prolly not. I think it might have been better to go with a 2.75" 90* and then a 2.75"-2.5" reducer. Or 3" to 2.5 set up.
05RLS2
Apr 14, 2016 11:49 AM
Stagnet04
Sep 14, 2015 11:28 PM
