Stripped the threading into the SC....am I screwed?
Old Mar 28, 2003 | 04:01 PM
ejj's Avatar
ejj
So, in the first of what I hope won't be many bone-headed moves, I stripped one of the holes used for mounting the SC to the plate. The one I stripped is the center hole in the back of the SC...the shortest of all the bolts.
Now, the hole doens't appear to need a bolt in it (not like an oil drain), and if there would be any that wouldn't be needed, I would think it would be that one.
Can I continue without it? I'm going to leave the bolt in to help with weight support, but it won't help hold the SC tight to the plate.
Old Mar 28, 2003 | 06:18 PM
[maxi-overdose]'s Avatar
bolt # 18?
the smallest hex bolt? that's a tricky one and I dont think you need that one to hold the plate.
Old Mar 28, 2003 | 07:00 PM
iansw's Avatar
I'm missing #16 - the threading stipped while installing the SC....never had a problem.
Old Mar 28, 2003 | 07:09 PM
ejj's Avatar
ejj
#6...smallest bolt holding the SC to the plate.
Old Mar 28, 2003 | 11:11 PM
oh...the one right in the center?
it's ok, mine's stripped too. you can wrap it with some teflon tape and push it in there.
Old Mar 29, 2003 | 09:49 AM
JAY25's Avatar
since its the center one dont worry about it. Your not the only one riding around with a loose bolt. Someone else has that center bolt loose. Its a blower I worked on that was shimmed. the bolt is just there for show
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
sliptap
Sep 30, 2015 05:57 AM
