I'm gonna need some part numbers and what not
Old Apr 1, 2003 | 08:02 AM
max'n out's Avatar
Seeing as how the search don't work, and I din't bring any real info with me when I moved I'll need the following.
NGK Platnum spark plug- 1 step colder
NGK platnum spark plug -2 step colder
Napa and Pep boys sell um if I remember correct.
Walbro fuel pump
that everyone is using and the place to get it...and any brackets i may need. How hard is it to unhook the aux fuel pump once this is in?
Ignitnition coils, all 6 I know somebody on line had um for like 300 for a set of somthing but i forgot who,was it courtusy nissan?
That should do for now, hopefully this crap will help the car run rite all the time.
Thanks.
Old Apr 1, 2003 | 10:29 AM
[maxi-overdose]'s Avatar
spark plugs
PFR5G-11 normal
PFR6G-11 1 step colder
???????? 2 step colder
I got it from Pepboys. I use copper instead though
FYI: BKR6G-11 1 step colder
Old Apr 1, 2003 | 12:26 PM
JAY25's Avatar
Re: I'm gonna need some part numbers and what not
Walbro fuel pump
Thanks.
simple disconnect the hose from the fuel filter and the hose thats on the top fuel rail and just direct connect the hose from your fuel filter the way it was hooked up when you were stock to the top fuel rail.
Old Apr 1, 2003 | 07:31 PM
PCGuRu2K's Avatar
Walbro fuel pump
Thanks.
Why do you need the ignition coils? Car running rouch idle?
Old Apr 1, 2003 | 10:10 PM
max'n out's Avatar
Re: Re: I'm gonna need some part numbers and what not
Aight heres what I got:
Walbro fuel pump:http://cgi.ebay.com/ebaymotors/ws/eB...0another%20guy
I need to shave off 2 tabs.
Dave B has coils for around 200ish all 6...888 254 6060
PFr6G-11 one step colder platniums.
Anybody wanna dispute this?
As for why I need the coils, my car is one of those with vins that fall within the likely hood of bad coils, no sence in waiting till it happens Ive had enough bad luck. Replace um now for 2-300 and save the headache later. Plus while I'm fixing everything else modaswell.
And I have no idea what running "rouch" means.
Old Apr 2, 2003 | 03:06 AM
PCGuRu2K's Avatar
Re: Re: Re: I'm gonna need some part numbers and what not
Sorry.. I meant rough idle..
Old Apr 2, 2003 | 09:15 AM
WizzaMax's Avatar
just so you know, the wiring and strainer will not be used in the Maxima install so you could resell teh unused items...only the actual pump is needed for ours..good price though if it fits in with the tabs off like you mentioned.
MR2 T'd
Jul 9, 2021 05:06 AM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxboy23
Sep 4, 2015 06:04 PM
mikebla
Sep 3, 2015 05:37 PM
