Oil on spark plugs
Old Apr 22, 2003 | 09:38 AM
xHypex's Avatar
Oil on spark plugs
This weekend I did a compression test and found oil on my plugs.
"I found oil on the threads of the plugs, so there must be a leak
from the valve cover or something. There wasn't too much oil, but does anyone know more about this? I was told that its relatively common, and as long as there aren't puddles it's not a huge issue (but at some point a new gasket set would solve the problem)."
http://forums.maxima.org/showthread....hreadid=208508
More pictures
-hype
Old Apr 22, 2003 | 10:21 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
It doesn't look bad. Did you remove your valvecover before? Did you replace the gaskets if you did?
Old Apr 22, 2003 | 10:43 AM
xHypex's Avatar
Yes I have removed my valve cover without replacing the gasket However, that was well over 20k ago, and last time I replaced my plugs ~5k ago I had no oil on them Also the valve cover gasket runs around the edge, but aren't there separate ring-type gaskets that seal the plug cylinder?
-hype
Old Apr 22, 2003 | 11:09 AM
Y2KevSE's Avatar
Originally posted by xHypex
Also the valve cover gasket runs around the edge, but aren't there separate ring-type gaskets that seal the plug cylinder? :confused
-hype
Yes, there are separate ring-type gaskets for each plug. Did you replace them? No?
Old Apr 22, 2003 | 11:15 AM
xHypex's Avatar
Well at least summer is coming up so I can replace the gaskets. I wonder if anyone has any part #s or anything for the gaskets. I know there's a gasket set, but I don't know what all it includes. Maybe search will return soon since it's after the 21st
And actually while I'm thinking about it: I have a little oil in each cylinder 1-6 as indicated by my pictures and plugs. I have removed the front valve cover (1,3,5) to polish it, but I haven't removed the rear valve cover (2,4,6) yet it has oil in it too
Anyway thanks for the comments Kev.
-hype
Old Apr 22, 2003 | 11:36 AM
Y2KevSE's Avatar
Call up Dave Burnette at 1-888-254-6060
You're welcome.
Search feature working after the 21st?
Miket2006
Mar 1, 2021 03:55 AM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
