Another problem
Another problem
I thought this was due to me using 87 octane gas... but now on 93 octane... i'll floor it.... hit full boost 10-11 psi... and only reach 1050-1100 deg. F, and about 80-90 psi fuel pressure... What gives? The car is soooo sluggish... like it's slower than i was before i supercharged...
I know my tranny is goin out.... but I don't see how that'd cause my egt temps to be so low... I mean it's obvious that I'm running super rich, but my f/p doesn't reflect that....Thoughts?
Originally posted by desertmaxima
Your maxima is punishing you for running 87 octane poison. How dare you. Check yer fuel filter. Sounds like a clog or something, and if not that then check yer fuel pump. Is yer fuel pump upgraded?
possibily the injectors are maxxed out?
Re: Another problem
Re: Another problem
Are you running 1 or 2 steps colder and 8:1 disc? I can't believe you weren't getting preignition/detonation boosted with 87octane. Egts are much lower I would say that is due to the higher octance fuel change. The hotter egts were probably a sign of some mild preignition.
Haven't pulled plugs.... injectors are not maxed out since I'm only hitting 90 psi tops.
Looks like I'm pullin plugs today after work! yay!
I would start with plug on cylinder no.5.....the last one on the fuel rail usually gets less fuel.
question for all:
I just recently re-gapped my plug to .035......and I noticed that my cruise EGT is much lower (610 celcius at 80 mph, 2700rpm) on a flat road. Does it have anything to do with smaller plug gap?? 740celcius after boosting. I have 1step colder and 8:1 @ 10psi.
thx
pulled plugs... they're fine... slightly brown with some carbon buildup on the first couple of threads.
Anyhoo, I did notice that if you look straight down towards the ac compressor from the engine bay... the alternator is clearly turned clockwise about 5 degrees.... and when in gear with the brakes, the alternator and pulley vibrate harshly... Think this could be the reason for all the damn noise?...
Hopefully tonight i'll do a quick tear down and see if i can align it.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
