Oil in SC inlet
Old May 18, 2003 | 04:35 PM
ejj's Avatar
ejj
Oil in SC inlet
I took the filter of the supercharger today to install my SC CAI, and in doing so I noticed that there was a slight bit of oil in the SC inlet. The impeller blades were clean.
I didn't have the crankcase vent. hose hooked up to the filter, so its not from that. Therefor I assume this is oil from inside the blower.
This normal I assume/hope?
Old May 18, 2003 | 04:59 PM
MardiGrasMax's Avatar
Mine has just a non visible resedue it only feels greasy, basically bone dry.
Old May 18, 2003 | 07:22 PM
Jer's Avatar
Jer
I have something to report as well, though I shouldn't be jumping to conclusions until I take the piping off...
When I was cleaning the engine bay a little bit a few weeks ago I noticed a greasy substance in the vicinity of the MAF socket on the s/c intake pipe... took a closer look to see a sweat-like effect going down the pipe towards the cone!
I haven't looked closer yet, but I assume that it's either some kind of gunk that just happened to hit the piping in that particular spot, or the blower is spitting oil upon release of throttle at boost (backpressure effects?). It sure seems to be motor oil though...
Old May 18, 2003 | 07:58 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
hmm.... seals going out...?
Old May 18, 2003 | 09:27 PM
ejj's Avatar
ejj
Blower only has 2000 miles on it....I sure hope not.
Old May 19, 2003 | 04:21 AM
turbomax97's Avatar
Well, there isn't any other reason for that much oil to be there that I can think of.... anyone else wanna take a shot?
Old May 19, 2003 | 05:18 AM
ejj's Avatar
ejj
I suppose it would be covered under warrenty (still stock pully), but I can't imagine why the seals would be bad already...
Old May 19, 2003 | 05:19 AM
Jer's Avatar
Jer
You guys aren't making me horribly happy right now
Old May 19, 2003 | 05:34 AM
turbomax97's Avatar
You're right ejj, there is no reason... call Vortech and see what they say about it.. I'm sure they'll just have you send it in for a quick seal replacement though, and yeah, it's still under warrenty. Good luck.
Old May 19, 2003 | 05:49 AM
Stephen Max's Avatar
There's no way oil can get from the bearings to the air inlet against the flow of air. There are types of oil seal that uses air flow as the sealing effect (pressurized labyrinth seals, to name one).
I think it's oil from the K&N filter.
Old May 19, 2003 | 05:52 AM
ejj's Avatar
ejj
That could be. I cleaned the inlet and installed a new filter (CAI) yesterday, so I'll look again in a few hundred miles, although I suppose I'd expect to see the same thing if the filter was at fault.
Old May 19, 2003 | 05:58 AM
turbomax97's Avatar
There's no way that's oil from the filter. I'm 110% sure that's motor oil dude. Besides, when was the last time you've seen dark brown filter oil?... Every other one i've seen is clear or pink. It's motor oil. And there's only one spot that it could have come from... I can see how it's odd for the oil to go backwards.... but maybe that's what's leaked out while the car was off... the rest just made it's way down the sc piping..
Old May 19, 2003 | 06:10 AM
The oil would be brown from filtered dirt. At any rate, I don't think we need to jump to conclusions just yet. If it's just oil from the filter, it should gradually get better as the excess oil gets used up. If it's the seals, it will gradually get worse. But I still maintain that it's not possible for oil to make it from the bearings on the other side of the impellor to the blower inlet. Hmmm, unless there's some weird vorticity in the airflow causing some recirculation at the inlet. Naaaah. Hmmmm. Naaaaah. Hmmmmmmm.
Old May 19, 2003 | 06:13 AM
ejj's Avatar
ejj
Yeah, the more I think about it, the more you would think that if oil could get past the seals, it would get caught in the impellor blade and send down the intake piping.
If its a leaking after the cars been shut off, you'd think it would end up at the lowest point (bottom of the compressor housing) rather than in the intake path.
Like I mentioned, brand new filter yesterday, so I'll have to wait a while to figure this out. I'll call vortech today though to see what they say.
Old May 19, 2003 | 06:14 AM
turbomax97's Avatar
well. Using your idea of the vorticity of the airflow the brown oil with filtered dirt would have been sucked into the pathway as well....
It's motor oil damnit
Old May 19, 2003 | 06:42 AM
ejj's Avatar
ejj
I know color doesn't mean much...but my oil that's in the now is much darker than that. Its seen about 2500 miles, and is close to black.
Old May 19, 2003 | 08:53 AM
turbomax97's Avatar
well the pic you showed us is on a silver surface with good lighting through it....
smell it!...
Old May 22, 2003 | 10:16 PM
Dave B's Avatar
Not DAVEB the parts guy
The fact that it looks like the oil goes around the whole inlet makes me think it's dirty oil from the K&N. Let's not forget that the SC moves a lot more CFM than stock so it's quite possible the SC could suck out much of the excess oil from the filter.
Dave
Old May 23, 2003 | 08:16 AM
BlackCat's Avatar
RIP '98 Maxima SE
If it was the K&N filter recharge oil shouldn't it still have a pink tinge to it?
Old May 23, 2003 | 08:31 AM
If it was clean, I'd say yes, but we're thinking here that the trapped dirt has changed the tinge from pink to brown.
Old May 23, 2003 | 08:57 AM
BlackCat's Avatar
RIP '98 Maxima SE
Looks more like yucky cooking oil to me. Unfortunately I get stuck cleaning the air vent on my countertop kitchen range and it sure looks like that.
Old May 23, 2003 | 09:06 AM
That's what I thought, too. Did Eric lose a hamburger in the intake?
Old May 23, 2003 | 09:09 AM
BlackCat's Avatar
RIP '98 Maxima SE
I doubt it...We would have seen some streaks of ketchup in there too
Old May 23, 2003 | 10:15 AM
WizzaMax's Avatar
mmmmm...cooking burgers in the manifold again?
Old May 23, 2003 | 10:19 AM
ejj's Avatar
ejj
That's where that went!
Probably have ground beef shooting out at the cars behind me!
Old May 23, 2003 | 07:35 PM
JAY25's Avatar
My blower had a bit of stuff in there.
Old Jul 1, 2003 | 07:22 AM
ejj's Avatar
ejj
I know you were all wondering....
Checked the blower this past weekend and there was no sign of oil.
Must have been from the filter.
Old Jul 1, 2003 | 07:27 AM
That's a relief!
This may be a dumb question, but do K&N filters come pre-oiled? I'm seeing conflicting information on this.
Old Jul 1, 2003 | 07:31 AM
ejj's Avatar
ejj
Um, I dunno. I was under the impression that they were. I though that's why they come wrapped in a plastic bag.
I didn't oil either filter before putting them on...
Old Jul 1, 2003 | 08:07 AM
Well, that's what I thought, too. I came across a cardomain site where somebody thought otherwise, but I seem to remember reading the literature that came with the filter that said it was pre-oiled. Thanks, Eric. Also thanks for the ASP link.
Old Jul 3, 2003 | 10:13 PM
LatinMax's Avatar
I had the same thing right after I put on my new K&N filter when I did the CAI write-up. I had the same exact pic as you and looked again like 2-3 weeks later and there was nothing. So I would agree that it is oil from the K&N filter.
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
