Things one should do after installing a S/C v1 on an auto?
searching isn't work in for me...and i got as much as i could from this forum, just wondering on other past experiences one may share here...
I should be getting a used v1 s/c soon.......and was wondering besides the vb mod & tranny cooler....what else do i need to do/replace to my Auto or in general for any s/c car...
for example is changing the fuel pump a must/good idea on a stock pulley?injectors, etc
thanks in advance
thanks in advance
It all depends.. How much boost do you plan on going?
If you do anything lower then a 3.125" you might think about upgrading the fuel pump, injectors. But if your running stock pulley them your stock internals/accesories will hold fine..
I would say EGT And FP gauges are required. Boost gauge is an option because you will never overboost on an SC. With FP gauge (a good one), you can actually figure out how much boost are you running.
If you plan to do a lot of drag racing...I would get a tranny cooler with fan and thermostat (B&M)...because the traditional cooler is more effective at high speed cruising than stop & go.
not sure about addding upgrading fuel pump though.....with the aux pump and 8:1....I am getting >100psi at WOT.
I couldn't fix your brakes, so I made your horn louder
i'm running your setup right now... www.cardomain.com/id/seximagtr for a list of parts.
Thanks for replies guys,
I'm not planning on running a lot of boost since I'm an auto for now...so stock pulley for now.
As far as guages...is it crutial to get them, as far as i understand they are just mainly for looks and informative info on how much boost you're getting at the time...Is there a guage that is a must so that I can monitor it to make sure everything is going according to plan with the s/c?
Seems like the Haynes 403 Transmission Cooler is the best tranny cooler to get since i do a lot of highway driving, and not too much stop and go. Where's the best place to get those? pep boys? or online somewhere?
thanks!
damn search button isn't working
thanks!
Originally posted by seximagtr
the only guage that tells you how much boost you're getting is the boost guage, there's plenty of others... I suggest getting an EGT and a fuel pressure guage.
like I've mentioned....get the EGT and FP first....if you are short on money....save the boost gauge later.
you can get Hayden in Pepboys
I drove around without any gauges for a year but I was using the stock pulley and wasn't always heavy on the throttle. I went one step colder platinum plugs as well. I suggest getting the gauges like everyone has mentioned above.
MattWithTheMaxima
06-30-2017 01:06 PM
rbaker100
08-31-2015 11:09 AM
kirkhilles
08-08-2015 10:53 AM
MikesChevelle
08-06-2015 11:36 AM
