Turbo probleme?
Old May 29, 2003 | 10:00 AM
MarcGXE95's Avatar
Turbo probleme?
When I'm working it hard and then the trafic plugs up and I let off the gas fast the exhaust shoots upward to near 1500F, I'm not even touching the gas???
Old May 29, 2003 | 10:16 AM
thebigsadler's Avatar
Re: Turbo probleme?
what?
Old May 29, 2003 | 10:17 AM
MacAlert's Avatar
How are you measuring the temp on your exhaust?
Old May 29, 2003 | 10:21 AM
Jeff92se's Avatar
I'm needing a caw
EGT sensor. Odd post but he IS an avionics technician. If he does have a turbo, after a hard run, the turbo is extremely hot. And since you slowed down, it heat soaks the engine. This is why you idle turbo cars for few minutes before shutting off the car.
Old May 30, 2003 | 12:35 AM
MarcGXE95's Avatar
I'll see about mabe adding a oil accumulator/cooler to see if it will dissipate the exess.
Thanks for the feed back.
Old May 30, 2003 | 04:34 AM
PCGuRu2K's Avatar
1500F is high
Old May 30, 2003 | 06:06 AM
Bags's Avatar
VG Ridah's Biatch Hoe
Re: Turbo probleme?
is it just your egt? or does t he temp gague go up as well??
My temp gague goes up under this condition, but not my egt's
user 11122324
42
Jul 18, 2022 03:35 PM
Unclejunebug
Apr 2, 2016 05:42 AM
homewrecker
Sep 24, 2015 07:01 PM
