Manual Boost controller or New wastegate spring?
Old Jun 23, 2003 | 04:20 PM
Bags's Avatar
VG Ridah's Biatch Hoe
I am debating this now. I ordered a POS manual boost controller and it will not go below 10-12 PSI.
I want 7-8 PSI up from the 5 PSI I am seeing now.
If I get the 9 PSI spring that should do me.
What I am MOSTLY concered about is boost creep. I am about to go to the 8:1 FMU and if I boost more than 8 PSI I might have a serious problem.
I am looking at an Air Tool controller as my boost controller, the rx7 guys dig them
Just curious what the general opinon is??
And the price is $15 for both
Old Jun 23, 2003 | 06:32 PM
sx7r's Avatar
Re: Manual Boost controller or New wastegate spring?
get both so you can get a minimum of 9psi with the spring and then use the boost controller to turn it up from there.
Old Jun 24, 2003 | 01:40 PM
qnpark8282's Avatar
Re: Re: Manual Boost controller or New wastegate spring?
i have a avcr for sale
electronic boost controller is most safe always accurate to the point. wanna buy it let me know used on my car
Old Jun 27, 2003 | 06:10 AM
Bags's Avatar
thanks qn, but I got a grainger valve and stuff for $15
Old Jun 27, 2003 | 03:13 PM
Engloid's Avatar
If you're worried about boost creep, you need to be thinking more about the flow rate of the turbo and/or the size of the wastegate....and less about the actual controller.
Old Jun 27, 2003 | 10:16 PM
Ramius83
Very good Engloid, but with running/staying under 10 psi, that is not much of an issue. With the current market of wastegates and their high-performance orientation, this is not a problem, especially with Bags running a Deltagate wastegate. He just needs a GOOD controller to control what boost he does have lol. And also, with that low of a psi setting, if boost creep were to occur, it may spike at MOST 1-2 psi above the current setting, which is WELL in the safe zone for our engines.......
BkGreen97
Apr 2, 2016 05:47 AM
imported_Nismo_max
Feb 17, 2016 03:39 AM
Starrider
Dec 18, 2015 04:43 AM
Stagnet04
Sep 13, 2015 09:32 PM
EdRomo86
Sep 12, 2015 07:49 PM
