At what boost pressure do you have to start worrying about the head gasket?
Old Jul 24, 2003 | 09:19 AM
Stephen Max's Avatar
I've got a 3" pulley ordered, so with a V1 blower that'll give me, what, about 11 psi?
So at what boost pressure do you have to worry about head gaskets blowing?
Old Jul 24, 2003 | 11:20 AM
BigDogJonx's Avatar
Hard to say, but at 12+psi you want to start worrying, not saying at 12-13psi its going to blow, but thats the point you want to either be pro-active and change it out or end up being re-active when you do blow it.
Dixit
Old Jul 24, 2003 | 04:40 PM
iansw's Avatar
I have th 3" Pulley and never get over 10PSI.
I usually only hit 9PSI.
But I think you're OK even if you do get lucky with the V1 and hit 11PSI. Remember - V1's blow about 1 PSI less than V2's.
Old Jul 24, 2003 | 06:33 PM
Yeah, I knew that, but I'm hitting 9 psi with a 3.25" pulley, and I figured 3.125" would get me 10 and 3" would get me to 11 psi. Maybe that's wishful thinking.
Old Jul 24, 2003 | 06:52 PM
iansw's Avatar
My bad - I have a 3.125"
I was smoking crack - 3" should be 11PSI.
Old Jul 24, 2003 | 06:59 PM
guestNX's Avatar
Tuned properly, I would say headgasket would hold closer to 20psi than 12.
Pistons should be your first concern.. which again depends on your setup, luck and how far you want to push it.. can hold up to around ~16ish...?
Everyone will tell you 10-12.
ps. no one take what i just said and cut their boost up to 15.5 and blame me if you have problems. I do not adivse it, but have first hand seen it done with no problems arrising short term (long term, dont know)
Old Jul 31, 2003 | 08:09 PM
JAY25's Avatar
You should be seen 10.5 PSI at least, 10 is right with that 3.125 but Mardigrasmax was looking at 10.5 with his V1 ask him and see.
Old Jul 31, 2003 | 09:00 PM
iansw's Avatar
I know Jay - as you know I'm also missing about 25-35hp.
Noone can explain it after a whole year - even 2 regular mechanics and 3 speed shops in the area and the entire NW Community, including Jeff92SE and mtrai760.
And the many, many posts about it over the last year....
Old Aug 1, 2003 | 09:58 AM
JAY25's Avatar
hmmm I dont know what to tell you, I know for a fact the test pipe gives you over 5-9HP, I know that for a fact thats when I started hitting 13.8's @ 104 the car was hell a fast after that $25 install. The rest comes from the VI
Old Aug 1, 2003 | 10:00 AM
iansw's Avatar
Yeah, well, the TEst Pipe isn't my issue, however.
I had been hoping the problem was a clogged Cat, but it's not.
I'll probalby be sending the blower back to be swapped for a V2 this fall, because that is all there is left to eliminate.
Old Aug 1, 2003 | 10:04 AM
JAY25's Avatar
You checked the Y pipe flex?
Old Aug 1, 2003 | 10:07 AM
iansw's Avatar
at least 4 times over the last year - and again last week.
EGT's look normal, Fuel Pressure looks good, etc, etc.
The only thing is that I appear to have a vacuum leak that noone, even experienced mechanics I've known personally for years can find.
Vacuum reads 17Hg when it hsould read 20.
Boost reads 8.5-9 max when it should regularly read 10-10.5.
Even put it on the Dyno and sat on top of the car under the hood and listened for leaks under boost - nothing.
Old Aug 1, 2003 | 10:17 AM
JAY25's Avatar
I dont know what to tell you, I wish I was near by to help you diagnose the problem
Old Aug 1, 2003 | 10:19 AM
iansw's Avatar
Yeah - thanks man - I just hope against hope everytime I look under my hood that I'll just go "OH!!!" - and find the problem.
Hasn't happened yet tho.
Old Aug 1, 2003 | 11:59 AM
ereet's Avatar
Re: At what boost pressure do you have to start worrying about the head gasket?
I was under the impression the overall build of our engine was very good. I would have thought the 400hp+ guys would have blown it to bits by now if it wasn't. I've been running the 3.00" for afew thousand miles now and it's running perfectly. Go for it, you should be fine
Old Aug 4, 2003 | 01:12 PM
mclarke's Avatar
can you build any kind of intake pressure system? i know on my eclipse (when i had it) i was able to build an intake leak tester and i could test everything from the IC pipes to the intake, etc, it was easy since you could pressurize it without haveing the engine on/running. Also i used to use a soap/water combination to find small air leaks, surprizingly i was able to get rid of most of them on the eclipse.
just my $0.02
FlaMark
25
Aug 28, 2015 10:15 AM
305head
Aug 26, 2015 09:03 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
acw
Aug 7, 2015 04:20 PM
