How many of you guys run the stock fpr with Walbro?
Old Aug 7, 2003 | 01:14 PM
Jeff92se's Avatar
I'm needing a caw
chatting with Dixit, he's using his stock fpr. The slightly higher idle/wot fp is not affecting him much. How are you guys doing it?
Old Aug 7, 2003 | 02:02 PM
Stephen Max's Avatar
Re: How many of you guys run the stock fpr with Walbro?
I'm running Walbro with stock fpr. My fuel pressure is about 7-8 psi higher than stock. I have noticed absolutely no difference from before. I'm getting the same mpg and there's no indication it is running rich (except when boosting when the 8:1 fmu takes over).
Old Aug 7, 2003 | 02:14 PM
Craig Mack's Avatar
All YOUR grammer belong to me
I'm running the Walbro FP on stock FPR. But I have an AEM FPR sitting in my room and an Apexi S-AFC on the way. My idle is 40psi and I want to get it down at least ~6psi, and use the s-afc to adjust richness/leaness across the power band.
I am hoping to pick up a significant power/mpg increase with the addition of these two new things with a diagnostic dyno.
Old Aug 7, 2003 | 02:15 PM
BigDogJonx's Avatar
Yeap on the dyno when my car was with all the mods and no turbo but the walbro was installed, a/f still pulled the normal 14:1 that most maximas do. Definetely wasnt running at all.
Dixit
Old Aug 7, 2003 | 02:22 PM
Chunger's Avatar
My other car is a Hybrid
Another one here... No FPG so I don't know what the readings are... I have a Sard waiting to be installed. I think I'm still running rich with the V2 FMU (8:1?) with the 3.12"... I should drop the base FP back down.
Old Aug 7, 2003 | 02:51 PM
Jeff92se's Avatar
I'm needing a caw
I mean I would imagine once the ecu goes closed loop(after warm up) the 02 would adjust at idle/part/wot.
FYI. I saw a SR20DET oem(I believe) FPR what was adjustable! Now you say big freakin' deal right? But the thing is it looked like it had the same size fitting as our stocker! Looked the same but had an adjustment **** on the top. I can't find it now(on ebay) and I also didn't know if that adjustment was for base or wot pressures but it would sure help eliminate some clutter in the engine bay.
Craig Mack's Avatar
SeximaGTR has the Walbro FP. With the addition of an FPR/S-AFC he picked up 20-30whp easy across the board from 3400rpm and below. (outside of boost). Now I know all us SC'ed guys could use that kind of power below boost.
Old Aug 7, 2003 | 03:05 PM
Jeff92se's Avatar
I'm needing a caw
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
This is another one. It "looks" like it will fit in the stock rail(3 gen anyway) but who knows? I'll ask the seller what is adjustable.
Old Aug 7, 2003 | 03:12 PM
Jeff92se's Avatar
I'm needing a caw
http://www.phase2motortrend.com/apadfuelpres.html
Here is an ad. Kinda unclear about the idle/wot fuel pressure. Looks like the adjustment is for base and has the ability to raise FP on boost. But it's limited to a 1:1 fp/boost ratio.
Maybe not such a good idea.
Old Aug 7, 2003 | 03:13 PM
Craig Mack's Avatar
I know for the AEM FPR you have to buy an adaptor peice to connect it to the fuel rail. Sx7r sells them for around 25 bucks. I'm sure he or someone could make an adaptor for this FPR if need be.
Old Aug 7, 2003 | 03:47 PM
Chunger's Avatar
Jeff, it doesn't suprise me that there may be a OE (albeit JDM) that is adjustable. I believe the screw spacing was 1 1/8" so it would probably work.
Old Aug 7, 2003 | 03:52 PM
xHypex's Avatar
I'm running a Walbro with the stock FPR and I see 40psi at idle and 50psi at WOT. I have a SAFC2 which helped me tune on the dyno, but overall I wasn't as rich as I thought I would be. Nismo also makes an adjustable FPR that's the same size as our stock fittings.
-hype
Old Aug 7, 2003 | 04:17 PM
Craig Mack's Avatar
-hype
50psi at full throttle?? That's it? I see 41psi at idle and 83psi at WOT. I guess i'm running insanely rich?
Old Aug 7, 2003 | 05:25 PM
Jeff92se's Avatar
I'm needing a caw
These are the measurements the guy emailed me back with.
1 hole w/o-ring : approximately 1mm gas inlet size
2 mounting holes approximately 33mm from center to center.
Old Aug 7, 2003 | 05:59 PM
Bags's Avatar
VG Ridah's Biatch Hoe
I am running the walbro and stock FPR.
I will be doing fuel pressure check this weekend.. Yes jaime that means at your house
Old Aug 7, 2003 | 08:11 PM
He's not boosted, Craig, he's juiced. Your 83 psi fp with a 3.125" pulley may be a little rich, but not insanely rich.
Old Aug 7, 2003 | 10:58 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Jeff: Is there such a thing as a "RB20det"?
I know there is a RB25DET, which I plan on shoeing into a 240 someday, but I've never heard of a RB20.
Old Aug 7, 2003 | 11:22 PM
Jeff92se's Avatar
I'm needing a caw
yes
http://www.terato.com/cars/Cararchive/MerzRB20.asp
5 sec on net search you wanger!
Old Aug 8, 2003 | 12:07 AM
IceY2K1's Avatar
26K connection...I don't search sheit!
Old Aug 8, 2003 | 09:45 AM
Craig Mack's Avatar
Oh. Shoot.
Old Aug 11, 2003 | 08:56 AM
SR20DEN's Avatar
VQ Wizard
Jeff I have the Walbro 255 HP now and still have my stock regulator in the tank. My fuel pressure did not increase any at all over stock. You can make the same thing in those pictures. Just get another OEM FPR, drill a hole in the top, weld on a bung and run a set srew into it. Instant adjustable OEM FPR. You can increase the base FP with one but to reduce the fp from stock more work will be required such as changing the spring inside the unit.
Old Aug 11, 2003 | 09:38 AM
96BLUMAX's Avatar
I am running stock with walbro. I used to have a weapon-r fpr on the car but was having issues with tuning it so i took it off.
LilVito
Oct 25, 2019 08:12 AM
homeyclaus
Sep 3, 2015 06:15 PM
4 door GT-R
Aug 22, 2015 07:50 AM
maxipower
Aug 21, 2015 11:10 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
