VQ30DET engine?
Old Sep 16, 2003 | 09:30 PM
jkklim's Avatar
VQ30DET engine?
Do any of you boosted guys have a VQ30DET engine? I was searching for that engine out of curiosity as an alternative to turbocharging the stock engine, and I found this site...
http://www.sssautomotive.com.au/Nissan.htm
Would it be safer to swap the VQ30DE with a VQ30DET than putting on a turbo kit on a stock engine? And would the swap even be possible?...because on the site it says the engine is designed for AWD.
Old Sep 16, 2003 | 10:08 PM
Bags's Avatar
VG Ridah's Biatch Hoe
1 person to my knowledge has done it.. tiley99, I think is his screen name... although I have not seen any posts from him...
Why not just use your current engine and slap a turbo on it?
Old Sep 17, 2003 | 09:54 AM
ereet's Avatar
Full engine swap is not possible due to the the way the engine is mounted. Swapping all the internals is however, as well as some of the other parts, like the intake manifold, etc. I don't know how the mounting was done for the turbo, it may be mountable via the stock method, but I doubt it. bags is right, Tilley99 is the only guy who's done it on the .org
Old Sep 17, 2003 | 01:48 PM
Redmax's Avatar
Redlinemax Owner
also i30krab
Old Sep 23, 2003 | 06:00 PM
Ninos_Maxima's Avatar
be the change u want2C
You would need to change some of the internals to match the FWD specs of your current tranny, and then change the mounts, All together it would cost around the same, But I think the VQ30DET should be better all around becasue it should have better injectors, ECU, low compresion pistons, and all the other neat things a FI comes with that a NA engine doesnt, I think it will be better to get this engine, Its a lot of work, but its well worth it, I did lots of research on this, Im planning to get a Turbo soon to
Old Sep 23, 2003 | 08:45 PM
Cutler's Avatar
Rob did the full swap, Tilley is his name. It fit but took some work
Old Sep 24, 2003 | 07:27 AM
TILLEYS99's Avatar
Lives in a 11sec maxima
Too bad im pulling it to replace it with a 3.5/6spd
Old Sep 24, 2003 | 08:57 AM
20th maxstyle's Avatar
Not posible. the VQ30det is from the late 80's and would not match up to anything in our cars. I called streetimports.com to ask.
Old Sep 24, 2003 | 09:00 AM
Redmax's Avatar
Redlinemax Owner
tilley just pulled the parts out of his car. they are now going in mine!!!!
Old Sep 24, 2003 | 09:35 AM
ereet's Avatar
I didn't do the full swap (har har I'm Rob too )
I didn't think he could get the block to fit. How'd he mate the transmissions? Why is he selling the internals rather than the full block itself
I think he just swapped in the internals
Old Sep 24, 2003 | 09:12 PM
Cutler's Avatar
Tilleys99 did the entire swap, I saw it. He tried to dyno it and it kept hopping of the dyno if I recall right
Old Sep 24, 2003 | 09:17 PM
mtrai760's Avatar
'Trynna' is not a word
The VQ30DET cannot be used in the Maxima, it was designed for a RWD platform, and the engine block is different, with different engine mounting points. You can however, use all the engine internals, and swap them into a VQ30DE block from the Maxima. That is what Rob (Tilley) did. Benefits? Lower compression pistons to withstand higher boost levels with less chance of detonation.
Old Sep 24, 2003 | 09:23 PM
Cutler's Avatar
Tilley fit that motor in the car, he turned it sideways, trust me I was in his shop in PA......
He made it a Tilley custom , he made it fit , it was alittle to the side.....
Old Sep 24, 2003 | 10:21 PM
nismology's Avatar
Originally Posted by Cutlr7
Tilley fit that motor in the car, he turned it sideways, and stuck it up his candy...oh nevermind...
J/k
Old Sep 25, 2003 | 08:46 AM
mtrai760's Avatar
I know he made it fit... with a VQ30DE block... I still have the pictures he posted saved on my HD... all the internals were swapped...
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
