Stock setup at 4PSI??
Old Sep 24, 2003 | 08:43 PM
Morfeus17's Avatar
Just wondering and maybe this question was posted before, can you run 5PSI on stock injectors, FPR, fuel pump, and 10:1 compression safely, assuming you stay below the 4-5 PSI threshold???
My next question is about the Vortech Universal FMU. To run 4-5 PSI, what configuration is neccessary, 10:1, 8:1, or 6:1???
Old Sep 24, 2003 | 11:35 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
6:1 is good enough for the fmu
all of those stock parts are fine.... of course you need either the in line fuel pump or the in tank high flow pump
Old Sep 25, 2003 | 12:31 AM
Bags's Avatar
VG Ridah's Biatch Hoe
Yes 4 PSI is the Limit on stock FPR and stock fuel pump.
And 8:1 on the fmu is a good one to have @5 psi , 6:1 will work @6+ psi
Old Sep 25, 2003 | 05:54 AM
turbomax97's Avatar
And why would you lower fuel pressure for a higher psi?.....
Old Sep 25, 2003 | 08:18 AM
Bags's Avatar
so you do not hit injector lock up
Old Sep 25, 2003 | 08:20 AM
Morfeus17's Avatar
Ok.. A couple of things to consider..... I have a Tial 38mm wastegate with a 5 pound spring configuration. This means my lowest boost setting is 5PSI. Accroding to you guys 4PSI is the limit on stock. So i guess I went pass the stock threshold.
As far as the Vortech Super Universal FMU, Vortech cliams their unit can regulate fuel pressure independently from the stock FPR. Would running this unit indepenently be better??? And since it is fully adjustable, I can set the fuel pressure in any increments. So, fuel pressure can be set to 5:1 if needed?
Since I'm using a 5 pound spring, will the fuel pump handle the boost requirements? I guess worse case senario, I'll by a 4psi spring instead.
Thanks for your response.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
jaydot901
Sep 29, 2015 01:18 PM
