Turbo/supercharger questions
Old Oct 7, 2003 | 07:36 PM
spd579's Avatar
ok guys, just a few questions:
which setup is more reliable?
which has better gas milage on everday driving conditions?
which will last longer? (milage wise)
which is cheaper to maintain?
what are pros and cons of each performance wise?
on a superharger will lower comp. pistons add hp or reliability?
just for kicks (i have no idea) can you use both at the same time?
what's the most power the stillen charger could yield?
thanks a lot im planning on getting one of these in the near future and still not very sure, so if you have any seperate opinions please tell.
Old Oct 12, 2003 | 09:18 PM
CiViC KiLLeR's Avatar
Will some person help this dude because I need to know the same things. :attention
Old Oct 12, 2003 | 09:37 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
all those answers can be answered if you used the search. they are common questions.
Old Oct 12, 2003 | 10:23 PM
Bags's Avatar
VG Ridah's Biatch Hoe
My Break Down Reply For Turbos
Think about this.... there are VERY few parts to these "kits". The ONE part that works the most is the turbo. The rest is either Pipes or couplings or oil lines. Same for the SC.
So YOUR question should be which TURBO/SC is more reliable. That is NOT an easy answer
If this is an HONEST concern.... stop modding your car
Goes back to the 1st question, but if the pipes are NOT stainless steel they will rust
Define MAINTAIN? if you mean keep running.. refer to the above answer
This is NOT so simple, basiclly if your still thinking about Hlh's kit, you need to start over.
IF YOU JUST lower the Comp. ratio?
Yes, Good luck
Unknown.. mardi made 370 WHP I THINK on the SC alone
my advuce.. get a turbo.. find a shop that will CUSTOM make the pipe and do it that way. It is MUCH easier than you think
Old Oct 14, 2003 | 02:59 PM
Thanks for the help!!!!!
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
