anyone using the sard fpr???
EJJ you right, people keep thinking the Cartech is an FPR when it is nothing but a glorified Vortech FMU with the ability to adjust discs without opening it, just by turning a ****.
With the Cartech you STILL need your OEM FPR. Like EJJ said, the only one that will do both is the Vortech SFMU.
Dixit
Dixit
They both are used to control fuel pressure, so technically they are both fuel pressure regulators. They do it in different ways and under different circumstances, though.
<Rocky to Bullwinkle: Thank you Mr Know-it-all!>
i dont really get this..... so if i get the sard, i should take off the oem fpr???? cuz i have the vortech fmu and another fpr on at the same time.... but somehow i am running way too rich at low rpms (75 fp at idle) and running leean in high rpms... should i take out the oem fpr????
I don't see how you're getting 75 psi at idle with the oem fpr. How do you have your fuel lines hooked up? They should go:
in tank fuel pump > fuel filter > aux fuel pump > fuel rail > fpr > Vortech fmu > return to tank
And make sure you have the lines to and from the fmu attached to the correct nipples.
Yes, the Sard fpr replaces the oem fpr. It is used to control fuel pressure during nonboosted operation of the engine. The fmu takes over once boost pressure builds up.
i do not have the aux fuel pump in my setup... i have no idea how it is hoked up... i have the fmu, and both the oem fpr and an aftermarket fpr
You can't run both the oem fpr and aftermarket fpr. Use one or the other.
If you don't have the aux fuel pump, do you have a high flow Walbro in-tank pump?
so i have to take out the oem fpr and use just the fmu and the aftemarket fpr?
i have the walbro, but havent put it in yet
in-tank fuel pump > fuel filter > fuel rail > aftermarket fpr > Vortech fmu > fuel tank return
Again, be sure your fmu is hooked up correctly.
thanks
i ll try it out
what if i run the stock pump with just the fmu|?? would it be too lean?
but do u think i need the walbro pump if i am not running the aux pump???
If the kit includes the aux fuel pump, then it's a safe bet the stock fuel pump is inadequate... Be safe and run either the aux fuel pump or get the hi-pressure version of the walbro.
The stock fuel pump is not enough, it maxes out at around 42-45psi which is not enough, thus why they include an aux pump. Best bet would be to install a walbro so you dont have to worry about the aux pump and wiring and all that crap.
Dixit
Dixit
