Air or fuel problem?!?!
Old Oct 23, 2003 | 11:32 AM
maxlinegtr's Avatar
This is my 4th day with the supercharger. I am having problems my car not kickin in. I step on it doesn't want to go anywhere. It bogs and startsto cut like around 3500 rpm. like a sputterin,limiter, cut off sound. Is it the fuel...not getting enough fuel or is it air ...not gettin enough air.
Should i change my fuel filter. Is it my cold air cuz I did not cut a bigger hole for the CAI. It can't be the fuel pump cuz I changed it to the Walbro, can it.
Old Oct 23, 2003 | 11:44 AM
JAY25's Avatar
did you hook up the fuel return lines correctly?
did you plug the walbro harness?
are all your pipes that feed air from the SCer tighted properly?
are you using a BOV or the bosh?
Old Oct 23, 2003 | 12:38 PM
maxlinegtr's Avatar
I beleive so, but if I didn't the car would not run would it?
I put everything back as if it were stock.
I tripled check all bolts ....it is tight
greddy bov
anythwhere else I should look? should i take it to shop?
Old Oct 23, 2003 | 12:39 PM
JAY25's Avatar
tigten up your BOV and see if that fixes your issue
Old Oct 24, 2003 | 12:15 PM
maxlinegtr's Avatar
Damn!!I guess its my fuel filter. changed it and I guess it runs fine now. .....stupid me.
BkGreen97
Apr 2, 2016 05:47 AM
Smackasmith
Feb 1, 2016 12:40 AM
aminus21
Sep 12, 2015 04:53 PM
lux97Max
Sep 4, 2015 05:42 PM
